Noise Generation Confusion
Started by cogwsn 7 years ago5 replieslatest reply 7 years ago182 views
I have to generate AWGN noise whose power is -100 dBm
I do the following calculation in MATLAB.
np_dBm = -100; % desired noise power in dBm
np_watts = 10^(-13); % noise power in watts
L = 1000; % length of noise signal
n = np_watts*(randn(1,L)+1i*randn(1,L));% computed noise
computed_noise_powerindBm = 10*log10((sum(abs(n).^2)/(length(n)))/(1/1000));
But my computed_noise_powerindBm never comes even near -100 dBm !
Sampling rate is 20 MHz, but I am not sure how will it help here.
What fundamental mistake I am doing !!
Sumit
Reply by oliviertNovember 23, 2017
The error is in the computation of n:
n = sqrt(np_watts/2)* ...
because here you compute an amplitude, and the power of the complex number (Expectation) is 2.
Reply by cogwsnNovember 23, 2017
Okk thats solved the issue.. thanks much :)
Reply by boryskNovember 23, 2017
Hi Sumit,
1) Why are you generating a complex noise? Is there any particular reason? You can generate a real-valued Gaussian noise simply by:
noise = randn(1,L);
2) Now you need to normalize it. Do you want your power to be peak power or rms power? By the calculations you provide I suppose you want rms. Normalize your noise by its own rms like this:
noise = noise/rms(noise);
3) Now you want to calibrate it to -100 dB:
noise = noise * 10^( -100/20 );
4) Now check your rms value in dB:
rms_dB = 20*log10(rms(noise));
5) Is it just a programming task or are you gonna use a real DAC to output the noise to some physical device? Remember that above calculations work only if you assume that a signal with rms of 0 dB corresponds to a physical signal power of 0 dBm. If your physical system is calibrated to a different value, you need to subtract it. Below you have an example of the full code that would work in a more general case:
calibrationLevel_dBm = 23.5; % physical dBm power output when the digital signal has rms of 0 dB
desiredNoisePower_dBm = -100; % desired power of the noise at the output in dBm
noiseLength = 1000; % length of the noise in samples
noise = randn(1,noiseLength);
noise = noise/rms(noise) * 10^( (desiredNoisePower_dBm - calibrationLevel_dBm)/20 );
rms_dBFS = 20*log10(rms(noise)); % rms in dB Full Scale (re. digital 1) of the digital signal;
rms_dBm = rms_dBFS + calibrationLevel_dBm; % digital rms adjusted for the calibration correctionn to account for the output of the physical device
I am an audio person so I usually operate on dB SPL, but the math is exactly the same. However, if I made any error, please correct me.
Cheers,
Borys
I work with complex signals (wireless comm). Hence I need complex noise. Your detailed information was very much helpful. Thanks a lot for your time ! :)
Sumit
Reply by dszaboNovember 23, 2017
How did you derive the value for np_watts?
What did you think the power of (randn(1,L)+1i*randn(1,L)) should be?  And why?
