PLL in presence of noise
Started by chess 9 years ago8 replieslatest reply 9 years ago365 views
Hi
Assume I have a vector of phases and I take a derivative from them and I obtained the frequencies however I am looking for to estimate the frequency of signal and by taking derivative I am obtaining a noisy vector of data, how would I extract the frequency of signal from my vector. I was thinking of using the mean command and this works very well when the data is not noisy however this method is not really robust to noise. Can anyone suggest me another technnique to extract the needed information from noisy data ?
Reply by SlartibartfastJuly 26, 2016
Have you done a web search on "frequency estimation"?   There are a number of techniques depending on what your unique constraints might be, but there's a lot of information already out there.
Reply by chessJuly 26, 2016
There are many technique for frequency estimation but I am looking for to estimate it using PLL and I have a estimate of phase and i have a vector of derivative of phase which gives me frequency all I want is technique to give me an estimate of frequency in the noisy vector I get after differentiation.
In another thread you mentioned obtaining frequency from a locked digital PLL, and I explained how to do that very accurately using the Phase Increment Register in the NCO and the integrator in the loop.
If the PLL is locked, the phase detector output and loop output will be only error quantities and will not have much to do with the signal or reference frequency unless the loop is poorly designed.
Right now your problem is not described well enough for people to help you very well.
Reply by Y(J)SJuly 26, 2016
Chess
I am not sure we understand the problem.
Differentiating always increases noise because it is a highpass filter. By taking the mean I assume that you mean a simple averaging filter, which is a primitive low-pass filter. You can improve this by using a properly designed low-pass filter.
However, you mention "PLL" in the title of you question. A PLL enables measuring the frequency in a different way from simple low-pass filter. A low pass LTI filter needs to be open to some constant bandwidth, on the other hand a PLL has some bandwidth, but it locks onto the signal (assuming the signal is within its capture range) and tracks it with this relatively small bandwidth. So, the way to recover frequency with a PLL is to observe the frequency of the VCO or NCO in the PLL.
Y(J)S
Reply by Rick LyonsJuly 26, 2016
Chess, Y(j)S makes a good point. As it turns out, there are digital differentiators that don't generate too much high-freq noise and their performance is pretty good so long as the input signal's predominate spectral energy is below Fs/4 Hz.
Having said that, you seem to have some real-valued sequence that represents the instantaneous phase of a complex-valued time sequence. If you differentiate that phase sequence you'll produce a real-valued sequence that's proportional to the frequency of your original complex-valued sequence. Is that what you really want to do? Are you, by any chance, trying to perform FM demodulation?
Thanks Y(J)S, Rick and Slartibartfas. I can estimate the phase of reference signal accurately and now I would like to use my PLL to track the frequency (estimate the frequency) . I have a vector of phases and I take a derivative respect to them to obtain frequencies (As Rick you mentioned, that's exactly I am doing) and I realized simple operation like mean(signal) does not yield into good estimate. Y(J)S as you mentioned that is what I am doing with my PLL, I have a estimate of phase (output of VCO) then I am differentiating respect to time to get frequency . I am only taking mean because when I have vector of data (noisy signal) and I need to extract frequency (I am looking for estimate of frequency) average might seem to be good option. Assume I designed a better low pass filter then what I should with it ? I can smooth the signal with different low pass filter with different window size but after all I am looking for one number only.
Reply by JOSJuly 26, 2016
I would try phase-unwrapping (unwrap() in matlab) followed by linear regression (e.g., polyfit(time,phases,1)).  Plot the unwrapped phase to make sure it generally follows a straight line without jump discontinuities or outliers.  After phase unwrapping, mean(diff()) should work better as well.
Reply by artmezJuly 26, 2016
This maybe stating the obvious, but are you prefiltering the input? Today's electronics have crazy wide bandwidth that lets in lots of noise. Do you have a range of frequencies of interest? If so, be sure to use a good bandpass prefilter to reduce noise energy and adjust the PLL loop filter.
Obviously, noise is anything you don't want in the signal. Some noise will naturally interfere with what you're looking for, and that's the worst kind, as it is not reversible. Only something like a Kalman filter (on the raw detector output) will help there, assuming that statistics are on your side. Any filter slows the time to "capture", so there must be tradeoffs for accuracy vs. capture time.
