Modify a FIR filter in the frequency domain a then accomplish IFFT
Started by Swift80 3 years ago●8 replies●latest reply 3 years ago●358 views
Hallo,
I would like to design a custom made FIR filter. I would start from an ordinary LP FIR filter designed by means of fdatool, for instance, and then modify the magnitude freq response of the filter. I would like to alter the pass-band of the FIR, passing from a flat response to an increasing slope in the pass-band.
Would it be possible to modify it in the frequency domain a the switch back to time domain by doing an IFFT and thus obtaining the filter's coefficients ?
Here is the script I used (I also modified the phase).
It seems that I get aliasing once back in the time domain.  Why is that and how what I want to do can be accomplished ?
Thanks a lot
clear all; close all; clc;
load('X_Band_sgn.mat') % Load the oriinal FIR filter (flat pass-band)
fc = 715e6;
dt = 1/fc;
duration = 10e-3;
dur = length(X_Band_sgn);
time = (0:dt:(dur-1)*dt);
df = fc/dur;
freq = (0:df:fc-df)-fc/2;
a0 = 2.25*ones(1,100);
a1 = -216*ones(1,100);
int1 = interp1([1, 201], [2.25,-216], 1:201);
ang_mod = [a0, int1, a1];
Yt = fftshift(fft(X_Band_sgn));
figure; grid minor; hold on;
plot(freq/1e6,10*log10(abs(Yt).^2))
plot(freq/1e6,unwrap(angle(Yt)))
plot(freq/1e6,ang_mod)
xlabel('Frequency (MHz)')
ylabel('Power [dB]')
s_dB = 10*log10(abs(Yt).^2);
id = find(s_dB > -1.5);
s_dB = 10*log10(abs(Yt).^2)+1;
ang = angle(Yt);
%design the rect to alterate the spectrum mag
k = 40;
dy = 0.12*k;
dx = id(end)-id(1);
y = dy/dx*(1:1:id(end)-id(1))+1;
vq = [ones(1,id(1)) y ones(1,dur-id(end))];
sp_dB = s_dB.*vq;
plot(freq/1e6,sp_dB)
xlim([-357.5 357.5])
ylim([-200 60])
sp_dB = sp_dB-1;
ylim([-200 60])
% New filter
sp_X = (10.^(sp_dB/20)).*exp(1i*(wrapToPi(ang_mod)));
sp_t     = ifft(ifftshift(sp_X)); %IFFT
Yt = fftshift((fft(sp_t)));
plot(freq/1e6,(angle(Yt)))
ylim([-190 60])
X_Band_sgn_mod = sp_t;
save('.\X_Band_sgn_mod.mat', 'X_Band_sgn_mod');
% generate x signal
pow = 15;
duration = 100e-3;
dur = round(duration*fc);
df = fc/dur;
noise1_i = wgn(dur,1,pow,50,'dBm');
noise1_q = wgn(dur,1,pow,50,'dBm');
noise_iq_app = (noise1_i.'+1i*noise1_q.');
% filtering x signal by using the new designed filter
yX_Band = filter(X_Band_sgn_mod,1,noise_iq_app);
%Shift the freq
y_X_Band_tot = yX_Band.*exp(-1j*2*pi*250e6*time);
Yt = fftshift(fft(y_X_Band_tot));
Reply by kaz●February 13, 2024
I think you are on the wrong path.
FIR2 function can do an arbitrary response.
Reply by Robert Wolfe●February 13, 2024
this recent thread discusses some of the potential perils of assuming that a FFT modification, will inverse back to the time domain as desired/assumed:
filtering using FFT/iFFT (dsprelated.com)
Keep in mind that filter design(coefficients) is distinct from applying filter.
Much of above linked thread is about applying filter. For coefficient design using inverse FFT is very common practice (FIR2 is based on that)
Right.  Thanks for that clarification.
Reply by Swift80●February 13, 2024
Thanks a lot for the answer. I'll take a look at the fir2 function to design the filter with arbitrary response.
Thanks for the reply Robert
Reply by neirober●February 13, 2024
You can also design for an arbitrary response using the Matlab function firpm (Parks-McClellan synthesis).
--Neil
Thanks a lot Neil, I'll take a look and try
