In Search of The Fourth Wave
Last year I participated in the first DSP Related online conference, where I presented a short talk called "In Search of The Fourth Wave". It's based on a small mystery I encountered when I was working on Think DSP. As you might know:
- A sawtooth wave contains harmonics at integer multiples of the fundamental frequency, and their amplitudes drop off in proportion to 1/f.
- A square wave contains only odd multiples of the fundamental, but they also drop off like 1/f.
- A triangle wave also contains only odd multiples, but they drop off like 1/f².
This pattern suggests that there is a fourth simple waveform that contains all integer multiples (like a sawtooth) and drops off like 1/f² (like a triangle wave). Do you know what it is?
In the talk, I suggest four ways to solve this mystery, and in the Q&A, one of the attendees suggests a fifth.
You can watch the talk here:
And you can run the Jupyter notebook on Colab by clicking here.
- Comments
Which was the suggested 5th method?
Convolving a square wave with itself.
Great video!
What exactly do the command "wrap" do?
As in;
def parabola_func(cycles):
ys = wrap(cycles) - 0.5
return ys**2
I am trying to find the C/C++ equivalent, thanks
It's defined in the notebook (https://colab.research.google.com/github/AllenDown...)
def wrap(cycles):
frac, _ = np.modf(cycles)
return frac
`wrap` uses `modf` to compute the fraction part of the number of cycles.
Should be easy enough to translate!
