An Efficient Full-Band Sliding DFT Spectrum Analyzer
Rick LyonsApril 1, 20217 comments
In this blog I present two computationally efficient full-band discrete Fourier transform (DFT) networks that compute the 0th bin and all the positive-frequency bin outputs for an N-point DFT in real-time on a sample-by-sample basis.
An Even-N Spectrum Analyzer
The full-band sliding DFT (SDFT) spectrum analyzer network, where the DFT size N is an even integer, is shown in Figure 1(a). The x[n] input sequence is restricted to be real-only valued samples. Notice that the only real parts of the delay elements’ complex-valued outputs are used to compute the feedback P[n] samples.
The Figure 1(a) network’s complex coefficients are defined by $e^{j2{\pi}k/N}$ where integer k defines the DFT bin index and is in the range 0 ≤ kN/2. This even-N network has N/2+1 parallel paths that compute the complex-valued X0, X1, X2,..., XN/2 DFT bin output samples. The multiply by 1/2 can be implemented with a simple binary right shift by one bit.
The Figure 1(a) even-N network was inspired by the Figure 4 network in Reference [1]. However, for real-valued input samples I’ve simplified the Reference [1] network (which has N parallel paths) and reduced its computational complexity to develop the above proposed Figure 1(a) network.
An Odd-N Spectrum Analyzer
To compute real-time positive-frequency odd-N-point DFT spectral samples we use the network shown in Figure 1(b). This odd-N network has (N+1)/2 parallel paths that compute the X0, X1, X2,..., X(N-1)/2 DFT bin output samples. Again the x[n] input sequence is restricted to be real-only valued samples. The Figure 1(b) network’s complex coefficients are defined by $e^{j2{\pi}k/N}$ where integer k is 0 ≤ k ≤ (N-1)/2.
Two surprising properties of both Figure 1 networks are: 1) although they use recursive complex multiplications the networks are guaranteed stable, and 2) the networks compute sliding DFT samples without a comb delay-line section required by traditional sliding DFT networks! (The Reference [1] network also has those two noteworthy properties.)
Implementation
Both Figure 1 networks are implemented as follows:
1) Set the outputs of the delay elements and the P[0] feedback sample to zero.
2) Accept the first x[0] input sample and compute the Xk[0] output samples for each parallel path.
3) Shift the data through the delay elements and compute the P[1] feedback sample.
4) Accept the second input sample and compute the Xk[1] output samples for each parallel path.
5) Shift the data through the delay elements and compute the new P[2] feedback sample.
6) And so on.
Computational Complexity Comparison
In case you’re interested in the computational workload of the Reference [1] network and our two proposed Figure 1 networks, have a look at Table 1.
Conclusion
I presented computationally efficient full-band sliding DFT networks that compute the 0th bin and all the positive-frequency DFT bin outputs for both even- and odd-N-point DFTs in real-time on a sample-by-sample basis. (No taxpayer money was used and no animals were injured in the creation of this blog.)
References
[1] Z. Kollar, F. Plesnik, and S. Trumpf, “Observer-Based Recursive Sliding Discrete Fourier Transform,” IEEE Signal Proc. Mag., Vol. 35, No. 6, pp. 100-106, Nov. 2018.
Comment by JProvidenzaApril 9, 2021
I notice this is posted on April 1.  Am I foolish to read it?
John P
Comment by Rick LyonsApril 9, 2021
Hi JProvidenza.
Ah ha. Such an interesting question. The answer is no, you would not be foolish to read it. (Perhaps I should have paid more attention to the date and posted this blog on April 2nd.)
Comment by JProvidenzaApril 11, 2021
Rick -
I couldn't resist the comment - it was too sweet a date!
Thanks for all your great posts.  I have a couple of your books that I've used for study - my background is not DSP, but it's great to stretch my brain on topics I was not introduced to in college decades ago.
John P
Comment by JProvidenzaApril 13, 2021
Rick -
Could you add a little info on how to interpret the output?
Thanks!
John P
Comment by Rick LyonsApril 14, 2021
Hi JProvidenza.
Well, ...the traditional sliding DFT, shown in the following diagram, is used to compute the real-time (one output sample for each new input sample) kth bin output of a N-point DFT. (The X_k[n] output is the kth bin output of a N-point DFT for the current input sample and the previous N-1 input samples.) The typical application of the traditional sliding DFT is to detect the presence, or absence, of spectral energy centered at the kth bin of an N-point DFT in real time.
If you wanted to simultaneously compute the k = 3, k = 5, and k = 7 bins’ outputs you would use the following network.
For real-valued x[n] input sequences, my blog’s Figure 1 networks are used to compute the 0th bin and all the positive-frequency bin outputs of an N-point DFT in real-time (on a sample-by-sample basis). Notice in my blog’s Figure 1 that, unlike the traditional sliding DFT, no N-length delay line stage is needed.
I hope what I've written here makes sense.
Comment by tushar_tyagi90November 5, 2021
Hi Rick,
I am not sure if my question is related to this exact article.
Could the sliding DFT be used to extract different bins of an OFDM signal which is not really like a sine wave. Also is it applicable on parallel samples?
Regards,
Tushar
Comment by Rick LyonsNovember 5, 2021
Hello tushar_tyagi90
This blog presents an efficient way to compute the N complex output bin samples of an N-point DFT in real time. By “real time” I mean that that for each data input sample all N DFT bin complex spectral sample values are computed. The output samples of this scheme are not valid until the Nth input sample has been applied to the network. [The traditional DFT (or radix-2 FFT) provides outputs only for every N input samples--it’s not “real-time”.] The networks in this blog's Figure 1 are only valid for real-valued input samples.
A sliding DFT network, on the other hand, computes a single complex output bin spectral sample of an N-point DFT in real time (one complex output spectral sample for each input sample).
I have no experience in OFDM processing, but if your OFDM processing requires you to compute all N output spectral samples of an N-point DFT in real time then one of the networks in this blog’s Figure 1 should achieve your goal.
If your OFDM processing requires you to compute, say 8, real time N-point DFT spectral samples (where N is greater than 8) then you merely need to implement 8 sliding DFT networks. That is, one comb section driving 8 separate resonator sections.
I must tell you, “traditional” sliding DFT networks can experience long-term stability problems. Several guaranteed-stable sliding DFT networks have been proposed in the literature but they’re more computationally intensive than the traditional sliding DFT. Last year I developed a guaranteed-stable sliding DFT network that is significantly more computationally efficient than the previously proposed guaranteed-stable sliding DFT networks.
My “new and improved” guaranteed-stable sliding DFT is described at:
"Improvements to the Sliding DFT Algorithm", DSP Tips & Tricks column, IEEE Signal Processing Magazine, Vol. 38, No. 4, July 2021.
I intend to write a blog at this dsprelated.com web site describing my new and improved sliding DFT network as soon as I have the time.
tushar_tyagi90, if you have any further questions for me please let me know.
