Digging into an Audio Signal and the DSP Process Pipeline
A Pre-existing Audio File
Let's say we have an audio file of interest. Let's load it into Audacity and zoom in a little (using View → Zoom → Zoom In, multiple times). The figure illustrates the audio signal: just a basic single-tone signal.
By continuing to zoom into the signal, we eventually get to the
point of seeing individual samples as illustrated below. Notice that
I've marked one of the samples in the figure. We'll look at this
sample more detail later.
In the figure, we have three audio samples. Based on the vertical scale on the left, we can see that the leftmost sample seems to have has the value zero, right? The second and third samples have values greater than zero and less than 0.5 respectively.
Using a C++ application, I extract the first four values from the signal. So, the listing below illustrates the first four signal values as they are read in from the WAV file.
Value of signal data[0] 0.000031
Value of signal data[1] 0.136047
Value of signal data[2] 0.268311
Value of signal data[3] 0.392517
Notice in the listing, that the WAV data tells a slightly different story from Audacity. Namely, that the first sample is in fact not zero. It has the value 0.000031.
Again, this shows the merit of using different perspectives. One tool (i.e., Audacity) gives us one perspective, but another, in this case, handcrafted C++ tool gives us a more accurate view of the same data.
Let's take the experiment a little further and include some more data (7 points) in the excerpt as illustrated in the following figure.
What does the C++ program output for the data in this figure look like? The following listing provides the details.
Value of signal data[4] 0.505493
Value of signal data[5] 0.603577
Value of signal data[6] 0.684082
More signal values
Notice in this listing that the last value is around the 0.684 mark.
In practice, it may not be necessary to delve into such fine detail. But, it's important to note that, with the right tooling, it is feasible to do so. Using multiple tools also facilitates the cross-checking of your signal data.
- Comments
![](https://d23s79tivgl8me.cloudfront.net/user/profilepictures/140483.jpg)
You can also get these values by selecting the audio and choosing (Tools → Sample Data Export), which opens this dialog:
C:\temp\sample-data.txt 1 channel (mono) Sample Rate: 44100 Hz. Sample values on linear scale. Length processed: 6 samples 0.00014 seconds. 1 0.00000 2 0.05012 3 0.10004 4 0.14957 5 0.19851 6 0.24667
![](https://d23s79tivgl8me.cloudfront.net/user/profilepictures/140690.jpg)
Good point and thanks for the feedback.
But, the exported data shows the first sample as having the value 0.00000, whereas, the other (C++) tool reports it as being non-zero, i.e., 0.000031. The point is that using two tools provides additional perspective on the signal data.
My sine wave isn't the same as yours. What does sample export show with the file from your post?
My version of Audacity (Windows) doesn't seem to have a Tools option (please see below). The data values in my post seem to be a bit different to the ones in your comment.
That is very strange. Maybe we are running different versions? I'm on 2.3.3
I'm on 2.2.2.
