Spread Sinc (ssinc) filter
Started by plinnie 8 years ago9 replieslatest reply 8 years ago370 views
The LTC2500-32 ADC has a so-called spread-sinc (ssinc) filter (datasheet). When googling the only references which turn up are from Linear it self. As far as I can tell it is a variant of a normal sinc filter. Does anyone know more about this filter, and how it was designed?
Kind regards,
Vincent
Reply by fred_harrisJanuary 4, 2018
Hello all,
I looked at the spectrum of one of the s-sinc filters: Once you see it, you know how the filter was designed. They are cascades of multiple CIC filters. instead of defining the filter as [(1-Z^(-M))/(1-Z^(-1))]^k we use one filter that appears to be zero packed to form multiple copies of the sinc spectral peak and then a second filter to drive down the multiple peaks:
the filter will look like
[(1-Z^(-4 M_1))/(1-Z^(-4))]^k_1 times [(1-Z^(-4))/(1-Z^(-1))]^k_2
run the following code to demonstrate above equation for M_1=6, k_1=8, k_2=4
fred harris
b1=[1 zeros(1,23) -1]; b2=conv(b1,b1); b3=conv(b2,b2);
bb=conv(b3,b3);
a1=[1 zeros(1,3) -1];  a2=conv(a1,a1); a3=conv(a2,a2);
aa=conv(a3,a3);
h1=filter(bb,aa,[1 zeros(1,160)]);
bb1=[1 zeros(1,3) -1]; bb2=conv(bb1,bb1);
bb3=conv(bb2,bb2);
aa1=[1 -1]; aa2=conv(aa1,aa1);
aa3=conv(aa2,aa2);
h2=filter(bb3,aa3,[1 zeros(1,40)]);
h3=conv(h1,h2);
figure(110)
subplot(3,1,1)
stem(h1,'linewidth',2)
grid on
subplot(3,1,2)
ff=(-0.5:1/2048:0.5-1/2048)*4;
plot(ff,fftshift(20*log10(abs(fft(h1/sum(h1),2048)))),'linewidth',2)
hold on
plot(ff,fftshift(20*log10(abs(fft(h2/sum(h2),2048)))),'r','linewidth',2)
hold off
grid on
axis([-2 2 -120 10 ])
subplot(3,1,3)
plot(ff,fftshift(20*log10(abs(fft(h3/sum(h3),2048)))),'linewidth',2)
hold on
hold off
grid on
Another comment... the zero-packed CIC that produces multiple spectral copies which are suppressed by a second CIC  is reminiscent of a filter design technique known as iterated FIR or I-FIR... In the I-FIR case we design a low pass filter at a low sample rate then up sample by zero packing which forms the multiple spectral copies which we reduce with a short FIR filter which essentially interpolates across the zeros in the up-sample process. This is essentially what the S-SINC process is doing by using the extension integrator...
using 1/(1-Z^(-M_1)) rather than 1/(1-Z^(-1))
Reply by plinnieJanuary 4, 2018
Hi Fred,
Thanks for your explanation, this was what I was looking for! I still need to digest it all, but I'm beginning to understand it. Also thanks for the matlab elaboration.
Kind regards,
Vincent
Reply by joko37January 4, 2018
Hi there,
Just to be sure...   Pgs 26/27 of the datasheet refer to the transfer function of the various implemented filters.  Both the sync and spread sync filter.  Also lists a reference to the actual filter coefficients that are used.  Isnt that what you were looking for ?
Best,  Jk
Hi Jk,
Thanks for your feedback. No, that was not really what I was looking for. I think the provided coefficients are more for simulation.
I actually expect the SINC filers to be implemented as Cascaded integrator–comb (CIC) filter inside the hardware, which is much more efficient hardware wise.
Now I was wondering what is the difference between a normal CIC filter design such as the SINC1-SINC4 and the SSINC, and how they achieved such a stop-band with a 'spread' Cascaded integrator–comb filter.
I hope that clarifies things.
Kind regards,
Vincent
Reply by kazJanuary 4, 2018
I just checked one ssinc filter and it is FIR with multiple coeffs. I don't see any CIC connection here.
Hi Kaz,
Okay, well, maybe you're right. I would not expect a sinc filter to be implemented as a FIR filter in hardware, but for this chip it is probably the right solution. As sinc filters are often implemented as CIC filters on hardware, I would expect the SSINC to also be able to be modeled as a kind of CIC filter. Reading the datasheet again, I may be wrong. Sorry.
Kind regards,
Vincent
In FPGA (and same applies to ASIC like this chip) classic FIR are common and resource is not a problem. Though CIC is favored for high rate changes. I don't think a filter will have a set for simulation then implemented as equivalent CIC in this case.
Post deleted by author
