Parallel and series connection, what difference it makes
Started by jtp_1960 9 years ago●4 replies●latest reply 9 years ago●235 views
Hi!
Lets assume you have two 1st order IIR filters:
    [b1 b2 a1 a2]
1 = [ 1 -1 -1 -1]
2 = [-1 -1 -1  1]
What difference in phase and magnitude responses it makes when you use these filters
  1. parallelly
  2. in series
Meaning does responses become summed, subtracted, etc..
EDIT: Here are the two filters plotted:
Reply by kaz●September 1, 2017
Without math I will use quick matalb commands:
a1 = [1 -1 -1 -1];
a2 = [-1 -1 -1 1];
freqz(1,conv(a1,a2)) %cascade
freqz(1,a1+a2)       %parallel & add results
Reply by jtp_1960●September 1, 2017
Your commands give these results in Octave:
Cascade:
Parallel:
When those two filters are used either parallelly or in series, shouldn't I be able to hear the -10dB - -15dB magnitude change showing in plots ... but, I don't hear it (actually, series connection does not change gain, parallel connection boosts gain) so, is what you suggested the right method to measure the differences I'm talking about?
according to rules of filter function you need to add initial 1 for IIR as below:
I also realised you are using b,a possibly meaning forward/reverse coeff
b1 = [1 -1];
b2 = [-1 -1];
a1 = [1 -1 -1];
a2 = [1 -1 1];
freqz(conv(b1,b2),conv(a1,a2)) %cascade
freqz(b1+b2,a1+a2)       %parallel & add results
As to your question you need to explain what is your input and how you observe output and what filters you use
This was just a technical question (I'm not EE so ...) but, I also tested by feeding normal audio stream through these filters one at time (both worked as expected (by the plot data got from here)) and when connected in series and parallel (result was different from my own expectation) --> that's why I placed the question).
Actually, both my filters are based on this code:
% 1st order all pass filter
% H(s) = (s/w0 - 1) / (s/w0 + 1) w0 = 2 * pi * f; % Hz to rad/s
b = [w0 -1];
a = [w0 1];
I jus rounded the a and b values because of all coefficients were so close to 1.0.
