DSP Windowing function
Started by Bheki 9 years ago7 replieslatest reply 9 years ago1031 views
Summary A beginner in FPGA development is seeking guidance on implementing a digital signal processing (DSP) windowing function in VHDL, specifically for processing data stored in Block RAM (BRAM).
A beginner in FPGA development is seeking guidance on implementing a digital signal processing (DSP) windowing function in VHDL, specifically for processing data stored in Block RAM (BRAM). The discussion focuses on the hardware architecture required for element-by-element multiplication and the trade-offs between manual VHDL coding and high-level synthesis.
  • A standard implementation uses a counter to simultaneously address the sample array and the window coefficient array for multiplication.
  • Memory can be saved by storing only half of a symmetric window function and reversing the address counter for the second half.
  • If manual VHDL is too complex, Xilinx Vivado HLS (High-Level Synthesis) can be used to generate the necessary logic from C or C++ code.
  • For testing purposes, users recommend generating temporal samples via MATLAB or C simulations before hardware deployment.
FPGADSPVHDLXilinx Vivado
Hi everyone
I am new in #FPGA programming, yet I have programming experience in using C, matlab, SQL, and other languages.
I am assigned a task of creating a Windowing function using Xilinx FPGAs in VHDL. I studied what windowing is and how it works. I have also done couple of examples in BRAMs, Dual Port RAMS, etc, and I did windowing function tutorials available in Vivado applications as examples. I am failing to put the whole thing together (like reading data from BRAM and multiplying it with signals coefficients). May I please be given the direction/logic on how do I approach this.
Any advice will be appreciated
Reply by raphAugust 30, 2017
Hi Bheki,
I guess you want to apply a window to an array of samples stored in Bloc RAM.
My experience with Spartan 3 (it doesn't change the matter as BR are similar or bigger now). Multiplication of an the array of samples (Signed samples) with a constant positive window array (Signed samples normalised).
A simple counter can be used to address both the sample array and the constant window array. And you need to store the sample at the output of the FPGA (Back in the BR).
I hope it help,
Raph
Reply by BhekiAugust 30, 2017
Hi Raph,
Do you perhaps know of any source where I can get temporal samples, just for testing
Thanks in advance
Reply by SlartibartfastAugust 30, 2017
It's just an element-by-element multiplication, so a structure with a counter or two and a multiplier is basically it.   If the window function is symmetric, which most are, and memory is constrained, you can cut the memory in half and add a little logic to reverse the counter when you get to the middle.
Reply by Tim WescottAugust 30, 2017
If resources are REALLY constrained you may end up needing to find windowing functions that are a better fit with the resources and finding which is most acceptable, rather than starting with the theoretically bestest and finding how to implement it.
This day and age, though, unless you're in a really high-volume price constrained market, or building a device that's power, or space, or otherwise constrained, you'll probably just throw more memory at it.
Reply by artmezAugust 30, 2017
Never discount the benefits of googling something, which too often is greatly affected greatly by how a search is phrased. I used "dsp window function for fpga" and got lots of hits.
It seems that although you have programming experience, you may not have FPGA experience (I don't either BTW) and may lack DSP experience too. I always start by examples of other (via the search above) and then build on that. I would work first in familiar turf by programming in MatLab or C and then build from there. In spite of VHDL being Cish, it has lots of nuance that comes with lots of reading, examples, and study.
Good luck.
Reply by Pierre_NowoAugust 30, 2017
If you are more comfortable with C or MATLAB and you dont't have to become an FPGA expert in the near future, you should look at HDL code generation solution from C or MATLAB.
Cheers !
Reply by oliviertAugust 30, 2017
I couldn't say a better advice!
Try Vivado HLS from Xilinx, you'll get what you need in a few minutes.
