Why low number of subcarriers is needed for high path loss scenarios ?
Started by 6 years ago●9 replies●latest reply 6 years ago●220 viewsIn one of the papers related to 5G numerology, I read this statement:
"Low number of subcarriers is needed for
because higher number of subcarriers result in high PAPR values which is not a
good condition for PA usage."
I am not able to figure out: Why low number of subcarriers is needed for high path loss scenarios ?
Sumit
Hi Sumit,
I think it is too obvious, you must be kidding, sorry.
Low subcarriers means you can use PA more efficiently and hence have better power level without saturation issues. But with DPD stuff(at gNB, not UE I assume) this would be less of an issue. So the mystery paper can argue for that.
Hi Kaz,
:D Well the second part of the sentence I understood but the first part was not obvious:
"Why low number of subcarriers is needed for high path loss scenarios?"
Here is the paper(open access): https://ieeexplore.ieee.org/stamp/stamp.jsp?tp=&arnumber=8263598
Page-3, second column, second last para.
Sumit
I'm with kaz, the answer was in your question. As the number of carriers increases the PAPR increases, which decreases the average power available for the signal, hence greater pathloss/shorter range.
Ok, I see. Yes, it was indeed a simple explanation.
In a DSL szenario with many carriers and high PAPR you just let the amplifier clip, which results in error bursts. These errors are spread over time with the descrambler and eliminated by the Reed-Solomon error correction.
Up to a point. At around 16 to 32 carriers, irrespective of modulation type, the statistics start approaching a Gaussian distribution, and PAPR is about constant. Or so I recall from my time at a now-defunct cellular basestation power amplifier manufacturer in the early 2000's. Should be applicable to OFDM, which was just coming out back then. I think the Gaussian approximation requires all carriers be at the same power or at least close.
Hi Sumit,
Number of subcarriers has to be reduced for long distance communication. Because the total probability of error for multicarrier systems in general depends on the number of subcarriers.
Thirunavukkarasu G
Hi Thirunavukkarasu,
Just to stimulate discussion. In that case I will send no subcarriers and get zero error. Apologies if it sounds sarcastic but it is not. I was once told by biology teacher if we eradicate all humans there will be no Malaria or Corona for today's mindset... it is true theoretically and is a hidden corner of implementation choices.
