Implementing octave algorithm in FPGA using c++
Started by Abhinav90 6 years ago11 replieslatest reply 6 years ago1365 views
I am currently working on writing a scrambler and DeScrambler code for Orthogonal Frequency Division Multiplexing(OFDM). I am planning to write an algorithm for BPSK, QPSK and QAM scrambler-Descrambler before modulation and transmission.
So far I have written an algorithm and test case  for BPSK and QPSK in Octave/Matlab and the code seems to work fine. Now I want to implement that in C++ so I can use Xilinx HLS to test my code on the FPGA for testing before I expand the algorithms.  The problem I am facing here is that I am quite new to C++ and feel more comfortable with Verilog and Sys Verilog but I have to write the codes in C++ for HLS to convert it into equivalent Hardware implementation:
Below is my Algorithm for the Scrambler in Octave, and if needed I can also provide the test case and code for DeScrambler.  Please check the queries after this code:
function [ScOutbits] = Scrambler(InputBits, BlockLen, ScramblerLUT)
   ScOutbits = [];
  switch (BlockLen)       % will be from test case usually either 1 or 2 depending on BPSK or QPSK
    case 1 %For BPSK, 1 bit per cyscle
      state = [ 1 1 1 1 1 1 1]; % represents the 7 bit state shift register using LFSR
      for k = 1:size(InputBits,2),
        xin = xor(state(4),state(7)); % polynomial used are x^7 and X^4 in this implementation
        state = [xin state(1:end-1)];
        ScOutbits(k) = xor(xin,InputBits(k));
      endfor
    case 2 % For QPSK, 2 bit per cycle
      for k = 1:1:size(InputBits,2)/BlockLen
        bit0 = InputBits(1,(k-1)*2+1);
        bit1 = InputBits(1,(k-1)*2+2);
        InputDataNum = 0;
        InputDataNum = bitset(InputDataNum,1,bit0);
        InputDataNum = bitset(InputDataNum,2,bit1);
        stateNum = 0;
        for I21 = 1:1:7
        stateNum = bitset(stateNum,I21,state(1,7-I21+1));
        endfor
        LUTIdx = stateNum + bitshift(InputDataNum,7);
        LUTData =  ScramblerLUT(LUTIdx+1);
        ScOutbits((k-1)*2+1) = bitget(LUTData,8);
        ScOutbits((k-1)*2+2) = bitget(LUTData,9);
        state = state = [ bitget(LUTData,7) bitget(LUTData,6) bitget(LUTData,5) bitget(LUTData,4) bitget(LUTData,3) bitget(LUTData,2) bitget(LUTData,1) ];
      endfor
  endswitch
** I have a few specific queries in this code snippet for C++:
* How should I implement the case 1 and Case 2 for loops in C++
* Is there any equivalent of bitset and bitget functions in C++ so I can get outbits
Note: I have built a mask to extract 1 bits from an integer to be used as inputs like the seven bit for shift register [ 1 1 1 1 1 1 1], as there is no C++ equivalent of vectors in Octave. I am stuck thereon,
Reply by oliviertJune 20, 2018
Hi Abhinav90,
apparently you want to use Vivado HLS so you should have a look to the User Guide 902 (UG902). Starting at page 614  (for the latest available version 2018.1) you have a description of the arbitary precision integer type ap_(u)int: all the functions and all teh redefined operators.
typically if you define a 7-bit integer like this:
ap_uint<7> State;
Then you can compute the next state by:
ap_uint<1> xin = State[4]^State[7]; // Bit Extraction (set or get) is the operator []
State = (State(6,0) , xin); // Concatenation is defined through the operator (high, low)
Reply by Abhinav90June 20, 2018
Hi oliviert,
Thanks for your reply, I am aware of that. The biggest problem I am facing is to how to retain the state of 2 bits when the blocklength is 2. I am trying to scramble multiple bits in the same cycle and I am unable to write equivalent C++ implementation like the octave code above. The bitset and bitget functions in Matlab/Octave make it easy to process multibits in same cycle but how to do the same thing in C++ is the problem for me.
FYI: In last w days I have managed to write code for single bit per clock cycle in c++, I need to tweak that for 2 bits now
Contact me oliviert@xilinx.com
Reply by oswaldfontysJune 20, 2018
Dear Abhinav90
I think you can convert MatLab to C++
See example:
Reply by kazJune 20, 2018
Apologies I am quite off topic and wish you find your way but we can nowadays:
convert vhdl to circuit..
convert Verilog to circuit
convert System Verilog to circuit
convert vendor ips to HDL or netlist...
convert vendor simulink blocks to HDL...
convert Mathworks matlab to HDL
convert C to HDL
convert M files to C then HDL
Do we have to learn all these, aren't we flooded with products that appear just because others want to get rich. Is there any sympathy left for field designers?
You're right about that kaz. My reply is more informative
I believe the tools all there to ease the Research and Development process. In my personal experience I have felt that once a person becomes used to a particular language and it toolset then the algorithms are easy to develop and the thought process becomes synchronized to it. I maybe wrong but coming from Embedded and FPGA background I have felt it. It maybe different for software developers
The same way you can use: C, C++, Python, Compiled Python, Java, ... to program your processor.
The same question could be asked!
The thing is that each language suits better to somebody or somebody else and it's your own choice.
Now for Hardware design it is different: you perform 'hardware design' but you do 'processor programming', all these MATLAB, Simulink, C, C++ to HDL is just a way to allow much more people (software programmers) to design hardware because HDL requires so much different thinking.
Hi oswaldfontys,
I tried this tool in Matlab but it is providing very fuzzy logic and not at all doing what it's supposed to do
Reply by mr_banditJune 20, 2018
There is a tool called SystemC that converts C (and looks like C++) into a HDL form. See (the first couple of responses when googling "systemc")
http://www.asic-world.com/systemc/tutorial.html
http://www.asic-world.com/systemc/index.html
https://www.doulos.com/knowhow/systemc/tutorial/
I have not personally used this, but I know some who have and were very happy.
Hi mr_bandit,
I have a tool to convert C++ into Verilog through HLS, what I am looking to do is a way to convert octave/matlab algorithm into c++ with similar logic
