Amplitude calculation from cross correlation data
Started by 7 years ago●4 replies●latest reply 7 years ago●609 viewsHey all,
I have this code for cross correlation between two signals shifted by 90 degree and having some attenuation:
fs=500000;
t = [0:1/fs:0.001];
A = 2;
f =5000;
y = 5*sin(2*pi*f*t);
y1 = 3.5*sin(2*pi*f*(t)-(pi/2));
x = xcorr(y,y1,'none');
tx = [-(length(y)-1):length(y1)-1]*(1/(fs));
figure(3)
subplot(2,1,2)
plot(tx,x)
% Determine the lag
[mx,ix] = max(x);
lag = tx(ix);
Given the first signal (amplitude 5V) and the cross correlation data between first and second signal, I want to calculate the amplitude of my second signal. How can I do this?
Thanks in advance!
Sounds like asking if I filter (x) with (h), if I know (x) and the output (y). Can I know (h)??? not sure but looks like sets of simultaneous equations scenario.
Kaz
Hey Amartansh,
From Cross correlation properties(wiki),
Analogous to the convolution theorem, the cross-correlation satisfies
- So finding the second signal amplitude is easy.
- Hope this helps !
Hi Charansai, that looks good idea but to get correlation equivalent mathematically between time domain and frequency domain care is needed regarding Fourier resolution, padding issues and scaling.
Kaz
Hi Amartansh. I think charansal is pointing you in the correct direction, and kaz's warning is sensible. It seems to me that you should explore the topic of "deconvolution." I suggest you have a look at the Chapter 17 deconvolution material from DSP guru Steven Smith at:
