Determining the frequency (between 1-100MHz) & amplitude of a sinusoid
Started by yloecher 2 years ago12 replieslatest reply 2 years ago212 views
An acquaintance of mine asked me the following question:
We have a bandlimited signal (say 0-100 MHz) that consists of a sinusoid plus white noise. Both the amplitude and frequency of the sinusoid are unknown (but frequency is in 1-100MHz). We can also assume that in the frequency domain - there will always be a discernible peak at the injected frequency reasonably above the noise floor.  We wish to determine the frequency and amplitude of the sinusoid.
Of course, we could just sample at > 200 MSPS, do the FFT and get the information.
However, for reasons of cost and FPGA resources (we have MANY such channels in parallel) we would like to undersample and "somehow" get the above required information (i.e. frequency and amplitude of the sinusoid).
I noticed some techniques such as Compressive Sensing or Sampling and also Nyquist Folding Receiver Architecture but I do not have enough expertise to judge whether these would work in our case.
Any insights would be very much appreciated.
Clayton Loecher
Reply by kazOctober 27, 2022
Since your bandwidth is 0 to 100MHz then you can't undersample and get frequency info.
Though you can get amplitude info wherever your frequency aliases to.
Reply by SlartibartfastOctober 27, 2022
Sounds like your client is susceptible to buzzwords.
Reply by lamabrewOctober 27, 2022
some questions:
  • How fast is the frequency changing?
    • Does it change monotonically?
  • Is there truly just one frequency peak?
  • what is the SNR?
  • Is the noise really white (i.e. you have measured it in an actual system) or is that an assumption?
  • what measurement accuracy do you need?
  • how often do you need to measure the frequency?
Reply by engineer68October 27, 2022
This is a classic task for a continuous fitting operation. I once wrote a module for this task in C that uses the minimum squares of the deviations and works iteratively. It can follow reasonable changes in both period and phase very efficiently. It also works with sine waves that contain massive harmonics. Later I transferred it to VHDL and created a core. Depending on the implementation, it is quite fast and tolerant of variations in the object parameters. The noise is the key point and determines the accuracy of the fit.
There is a core available, but for this task here, the FFT may be less resource intensive.
Reply by dudelsoundOctober 27, 2022
If the carrier is far enough above the noise floor, you could boost the input signal into clipping and just count positive zero crossings with a counter and read/reset that counter at a given interval. The average of that value should be a little bit above the carrier frequency (some additional crossings due to noise).
Then you could subsample the (unclipped original) signal at say 10MHz, find the dominant peak (alias) and measure the amplitude. The frequency of the alias could have been caused by different original carriers, but in combination with the rough counter signal, you could determine which was the original signal frequency.
Markus
That makes some sense if zero crossing is cared for. And is practical for FPGA platforms. It is worth trying but then you might just measure amplitude in time domain and spare any FFT.
Reply by kchuckOctober 27, 2022
You can certainly undersample (aka subsample) provided that the signal bandwidth is narrower than the sample rate.  It's done all the time, creating Nyquist zones.  You need to filter out the images after subsampling.  Frequency translation of the filtered signal to baseband is recommended.  Once at baseband there are many ways to extract frequency and amplitude, depending on the desired accuracy and measurement rate.  Interpolation followed by an FFT works well.
Reply by aa1wwOctober 27, 2022
Every disclaimer for ignorance is claimed ...
Given that the desired signal is a fixed frequency sinusoid whose power exceeds (by some amount) the noise, could you not undersample and determine frequency by comparing detected aliased frequencies?  I'm not sure if this saves much hardware.  Maybe it could be part of a per-channel pipeline of detection.
Coop
aa1ww
Reply by heycosmoOctober 27, 2022
You can try the Sparse Fourier Transform.
https://en.wikipedia.org/wiki/Sparse_Fourier_trans...
https://groups.csail.mit.edu/netmit/sFFT/
For a single sinusoid as in your case, you might get by with just the Chinese Remainder Theorem. Your approach would go something like:
- Assume some sample rate >200 MSPS
- Choose your frequency resolution
- The combination of the above two steps gives the number of ideal FFT bins (i.e. number of samples), N (could be large)
- Find K coprime integers N_1,N_2,...N_K such that their product is approximately N (let's say it's exact N=N_1 x N_2 x ...)
- Do K FFTs of lengths N_1,N_2,... (sample strides are N/N_1,N/N_2,... respectively)
- Find the peak bin k_i in each FFT of length N_i. Assuming k is the bin of your sinusoid for the ideal full FFT of length N, you then have a system of equations
k = k_1 (mod N_1)
k = k_2 (mod N_2)
etc.
See https://en.wikipedia.org/wiki/Chinese_remainder_th... to recover k.
Remember this is fpga platform and main theme is centred on simple resource efficient solution. If I can sample at correct rate and do one fft there is no issue but OP is asking for simpler solutions.
OP seemed to prioritize undersampling. My solution does not sample at the correct rate, it undersamples (by a possibly large factor). You can undersample if you know your spectrum is sparse. This is what compressed sensing is all about.
It's true, though, that I don't know how resource intensive the whole algorithm would be on a FPGA. But at least you don't have to sample at >200msps.
I don't really see why using different FFT lengths would be related to undersampling, but maybe I just didn't get it. But the Chinese remainder thing is ingenious!
You could undersample the signal at a bunch of different frequencies - two co-prime frequencies in the MHz range should be enough - and from the different alias frequencies you could figure out the original frequency.
