delay error due to quantization
Started by jgruber 4 years ago2 replieslatest reply 4 years ago153 views
Hi guys,
I have two random signals (created by matlab randn), where the second signal represents only a delayed version (by a fraction of an integer) of the first one:
x2[n] = x1[n-fd]
n ... discrete time index 0,1,2,3,4....N
fd ... fractional delay (0,1)
When I correlate the two signal and look for the fractional sample delay I obtain exactly the same value.
As soon I apply a amplitude quantization (1 and 2 bit) of the signals x1 and x2, the fractional sample delay I obtain by correlation is different. (see the plot below)
Plot description:
When I compare the input fraction delay with correlated delay (difference on the y-axis) for various fraction delays between 0 and 1 (x-axis) I see this patterns for 1 and 2 bit quantization. The 64 bit representation of the two signals (no quantization) shows no difference. So there is only a difference once I apply amplitude quantization.
Is this a known error when applying a quantization of a noise signal? If yes, would it be possible to point me to some literature or explain this behaviour?
Best regards,
Jakob
Reply by kazMay 19, 2020
Trying to understand your test:
Your x1 is generated from randn
your x2 is generated from FD of x1 (how?, do you apply FD filter).
if my samples are 0 and 1 only(1 bit) I don't see how I can get a value in between 0 & 1
Reply by jgruberMay 19, 2020
Thanks for your question kaz. I realized that I missed a bandpass filter after my fraction delay application. So the problem wasn't the quantization but the fractional delay application carried out before.
Cheers,
Jakob
