Sign in
username:
password:
Not a member?
Search blogs
Search tips
Articles by category
Our Bloggers
DSP Blogs > Rick Lyons > Computing Large DFTs Using Small FFTs
Rick Lyons
Richard (Rick) Lyons is a consulting Systems Engineer and lecturer with Besser Associates in Mountain View, California. He is the author of "Understanding Digital Signal Processing 2/E" (Prentice-Hall, 2004), and Editor of, and contributor to, "Streamlining Digital Signal Processing, A Tricks of the Trade Guidebook" (IEEE Press/Wiley, 2007). He is also an Associate Editor for the IEEE Signal Processing Magazine.
RSS Feed
Would you like to be notified by email when Rick Lyons publishes a new blog?
Posted by Rick Lyons on Jun 23 2008 under Tips and Tricks
It is possible to compute N-point discrete Fourier transforms (DFTs) using radix-2 fast Fourier transforms (FFTs) whose sizes are less than N. For example, let's say the largest size FFT software routine you have available is a 1024-point FFT. With the following trick you can combine the results of multiple 1024-point FFTs to compute DFTs whose sizes are greater than 1024.
The simplest form of this idea is computing an N-point DFT using two N/2-point FFT operations. Here's how the trick works for computing a 16-point DFT, of a 16-sample x(n) input sequence, using two 8-point FFTs; we execute the following steps:
  1. Perform an 8-point FFT on the x(n) samples where n = 0, 2, 4, ..., 14. We'll call those FFT results X0(k).
  2. Store two copies of X0(k) in Memory Array 1 as shown in Figure 1.
  3. Next we compute an 8-point FFT on the x(n) samples where n = 1, 3, 5, ..., 15. We call those FFT results X1(k).
  4. Store two copies of X1(k) in Memory Array 3 in Figure 1.
  5. In Memory Array 2 we have stored 16 samples of one cycle of the complex exponential e-j2πm/N, where N = 16, and 0 ≤ m ≤ 15.
  6. Finally we compute our desired 16-point X(m) samples by performing the arithmetic shown in Figure 1 on the horizontal rows of the memory arrays. That is,
    X(0) = X0(0) + e-j2π0/16·X1(0),
    X(1) = X0(1) + e-j2π1/16·X1(1),
    X(15) = X0(7) + e-j2π15/16·X1(7).
The final desired X(m) DFT results are stored in Memory Array 4.
Figure 1: 16-point DFT using two 8-point FFTs.
We describe the above process, algebraically, as
X(k) = X0(k) + e-j2πk/16 · X1(k) (1)
and
X(k + 8) = X0(k) + e-j2π(k+8)/16 · X1(k) (1')
for k in the range 0 ≤ k ≤ 7.
Notice that we did nothing to reduce the size of Memory Array 2 due to redundancies in the complex exponential sequence e-j2πm/N. As it turns out, for an N-point DFT, only N/4 complex values need be stored in Memory Array 2. The reason for this is because
(2)
which involves a simple sign change on e-j2πm/N. In addition,
(2')
which is merely swapping the real and imaginary parts of e-j2πm/N plus a sign change of the resulting imaginary part.  So Eqs. (2) and (2') tell us that only the values e-j2πm/N for 0 ≤ mN/4-1 need be stored in Memory Array 2. With that reduced storage idea aside, to be clear regarding exactly what computations are needed for our 'multiple-FFTs' technique we leave Memory Array 2 unchanged from what is in Figure 1.
The neat part of this 'multiple-FFTs' scheme is that our DFT length, N, is not restricted to be an integer power of two. We can use computationally efficient radix-2 FFTs to compute DFTs whose lengths are any integer multiple of an integer power of two. For example, we can compute an N = 24-point DFT using three 8-point FFTs. To do so, we perform an 8-point FFT on the x(n) samples, where n = 0, 3, 6, ..., 21, to obtain X0(k). Next we compute an 8-point FFT on the x(n) samples, where n = 1, 4, 7, ..., 22 to yield X1(k). And then we perform an 8-point FFT on the x(n) samples, where n = 2, 5, 8, ..., 23, to obtain an X2(k) sequence. Finally we compute our desired 24-point DFT results using
X(k) = X0(k) + e-j2πk/24 · X1(k) + e-j2π(2k)/24 · X2(k) (3)
X(k + 8) = X0(k) + e-j2π(k+8)/24 · X1(k) + e-j2π[2(k+8)]/24 · X2(k) (3')
and
X(k + 16) = X0(k) + e-j2π(k+16)/24 · X1(k) + e-j2π[2(k+16)]/24 · X2(k). (3'')
for k in the range 0 ≤ k ≤ 7. The memory-array depiction of this process is shown in Figure 2, with our final 24-point DFT results residing in Memory Array 6. Memory Array 2 contains N = 24 samples of one cycle of the complex exponential e-j2πm/24, where 0 ≤ m ≤ 23. Memory Array 4 contains 24 samples of two cycles of the complex exponential e-j2π(2m)/24.
Figure 2 24-point DFT using three 8-point FFTs.
To conclude this blog, we mention that the larger the size of the FFTs the more computationally efficient is this 'multiple-FFTs' spectrum analysis technique. This behavior is illustrated in Figure 3 where we show the number of complex multiplies required by the 'multiple-FFTs' algorithm versus the desired DFT size (N). The top bold curve is the number of complex multiplies required by the standard (inefficient) DFT algorithm, and the bottom dashed curve is the number of complex multiplies required by a single N-point radix-2 FFT. The curves in the center of the figure show the number of complex multiplies required by the 'multiple-FFTs' algorithm when various FFT sizes (P) are used to compute an N-point DFT.
Figure 3 Number of complex multiplies versus N.
Rate this article:
5
Rating: 5 | Votes: 3
posted by Rick Lyons
Previous post by Rick Lyons: Linear-phase DC Removal Filter
all articles by Rick Lyons
Comments
kaushik l wrote:
6/29/2008
nice blog but I didn't quite understand why an FFT of larger size makes the evaluation of DFT more computationaly efficient. Isnt a large FFT, say 16-point FFT obtained in turn from multiple 4-point FFTs?
Rick Lyons wrote:
6/29/2008
Hi,
Perhaps I didn't make my point very well. What the last part of the blog is trying to say is that if you want to perform a 24-pt DFT then it's better to use three 8-pt FFTs rather than use six 4-pt FFTs.
[-Rick-]
franchouze wrote:
8/27/2008
Hi,
Is this approach still valid for 2D DFT by:
-replacing 1D arrays by 2D arrays and taking one sample over n in each dimension (n is the number of FFTs used)
-replacing the memory array 2 of figure 1 by the product of itself with its transpose to obtain a square array ?
François
Rick Lyons wrote:
8/27/2008
Hello Francois,
I'm sorry to say, I've no experience in 2-dimensional (2D) signal processing. But if your 2D processing involves performing 1D FFTs, then the above approach should work. Signal processing software modeling should answer your questions.
Good Luck,
[-Rick-]
Add a Comment
You need to login before you can post a comment (best way to prevent spam). ( Not a member? )
