Sign in
username:
password:
Not a member?
Search blogs
Search tips
Articles by category
Our Bloggers
See Also
Embedded Systems
DSP Blogs > Rick Lyons > Linear-phase DC Removal Filter
Rick Lyons
Richard (Rick) Lyons is a consulting Systems Engineer and lecturer with Besser Associates in Mountain View, California. He is the author of "Understanding Digital Signal Processing 2/E" (Prentice-Hall, 2004), and Editor of, and contributor to, "Streamlining Digital Signal Processing, A Tricks of the Trade Guidebook" (IEEE Press/Wiley, 2007). He is also an Associate Editor for the IEEE Signal Processing Magazine.
RSS Feed
Would you like to be notified by email when Rick Lyons publishes a new blog?
Posted by Rick Lyons on Mar 30 2008 under Tips and Tricks
This blog describes several DC removal networks that might be of interest to the dsprelated.com readers.
Back in August 2007 there was a thread on the comp.dsp newsgroup concerning the process of removing the DC (zero Hz) component from a time-domain sequence [1]. Discussed in that thread was the notion of removing a signal's DC bias by subtracting the signal's moving average from that signal, as shown in Figure 1(a).
DC Removal Figure 1
Figure 1.
At first I thought such a DC removal scheme would have the very poor passband peak-peak ripple performance of roughly 13 dB because of the 13 dB stopband ripple of a moving averager. But upon modeling this DC removal scheme I found that its passband behavior was better than I had expected. My modeling involved a computationally efficient D-point moving averager (MA), shown in Figure 1(b). The bottom path, in Figure 1(b), is a simple delay line having a length equal to the averager's group delay, (D-1)/2 samples. This enables us to time-synchronize the averager's v[n] output with the x[n] input in preparation for the subtraction operation.
The D-point moving averager (MA) in Figure 1(b) has a transfer function defined by
DC Removal Equation 1
The second ratio in Eq. (1) is merely a recursive running sum comprising a D-length comb filter followed by a digital integrator. There are two delay lines in Figure 1(b); the bottom path's (D-1)/2 length delay, and the comb subfilter's delay line of length D within the MA.
This DC removal network's passband performance, when D = 31, is shown in Figure 1(c). (The frequency axis value of 0.5 corresponds to a cyclic frequency of half the input signal's Fs sample rate.) While the network has the desired infinite attenuation at zero Hz, its passband peak-peak ripple is unpleasantly large at 2.9 dB. We can do better, as we shall see.
If D is an integer power of two the 1/D scaling in (1) can be performed using a binary right shift by log2(D) bits, making Figure 1(b) a multiplier-free network. However, in that scenario the MA's group delay is not an integer number of samples, making it difficult to synchronize the delayed x[n] and the v[n] sequences. To solve this problem we can use two cascaded D-point MAs as shown in Figure 2(a). Because the cascaded MAs have an integer group delay of D-1 samples, we can be clever and tap off the first moving averager's comb delay line eliminating the bottom-path delay line in Figure 1(b). This way we still only need implement two delay lines in Figure 2(a), one delay line for the comb subfilter in each MA.
DC Removal Figure 2
Figure 2.
The magnitude response of the Figure 2(a) dual-MA DC removal network, for D = 32, is shown in Figure 2(c). In that figure we show the DC removal filter's passband with its narrower transition region width and a much improved peak-peak ripple of 0.42 dB. What we've created then is a linear-phase, multiplierless, DC removal network having a narrow transition region near zero Hz.
Happily, it's worth noting that standard tapped delay-line, linear phase, highpass FIR filter designs using least-squares error minimization, or the Parks-McClellan method, require more than one hundred taps to approximate our D = 32 DC removal filter's performance.
On a practical note, the MAs in Figure 2(a) contain integrators that can experience data overflow. (An integrator's gain is infinite at DC.) Using two's complement fixed-point arithmetic avoids integrator overflow errors if we ensure that the integrator (accumulator) bit width is at least:
DC Removal Equation 2
where q[n] is the input sequence to an accumulator, and ékù means: if k is not an integer, round it up to the next larger integer.
For an even narrower transition region width, in the vicinity of zero Hz, than that shown in Figure 2(c), we can set D to a larger integer power of two, however this will not reduce the DC removal network's passband ripple.
At the expense of three additional delay lines, and four new addition operations per output sample, we can implement the linear phase DC removal filter shown in Figure 3(a). That quad-MA implementation, having a group delay of 2D-2 samples, yields an improved passband peak-peak ripple of only 0.02 dB, as shown in Figure 3(b), as well as a reduced-width transition region relative to the dual-MA implementation.
DC Removal Figure 3
Figure 3.
The DC removal network in Figure 3(a) contains four 1/D scaling operations which, of course, can be combined and implemented as a single binary right shift by 4log2(D) bits. So the bottom line to this blog is that at the expense of multiple delay lines, it is possible to efficiently perform linear-phase DC removal.
[1] Posts during July 31 - August 8, 2007, Subject: "Regarding DC removal filter".
Rate this article:
5
Rating: 5 | Votes: 3
posted by Rick Lyons
Previous post by Rick Lyons: Free DSP Books on the Internet
Next post by Rick Lyons: Computing Large DFTs Using Small FFTs
all articles by Rick Lyons
Comments
an2or wrote:
4/3/2008
Rick
As always, an excellent and informative article!
Regards,
Andor
lishenghu365 wrote:
4/15/2008
Thanks ,it is a terrific job!!!
bluewhale wrote:
7/23/2008
Thats whats expected from an ace.
xie.qiang wrote:
4/9/2009
Hi Rick,
It's perfect.
Since there is attenuation at around the very low frequency for the DC revomal filter. Is there any way to remove the low frequency DC by using this filter?
Rick Lyons wrote:
4/10/2009
Hello xie.qiang,
Sorry, I'm not sure what you mean by "low frequency DC". The filter has infinite attenuation at DC (zero Hz).
Regards,
[-Rick-]
xie.qiang wrote:
4/15/2009
Hi Rick,
I means that when the signal frequency is very low compare to the sampling rate, say 20 Hz with the sample rate of 192KHz, and the DC removal filter will also attenuate the 20Hz signal but what I really want to do is need to removal the DC in the 20Hz signal.
Hope this could be clear. :-)
Rick Lyons wrote:
4/15/2009
Hello xie.qiang,
I am still having trouble understanding you. What do you mean by "the DC in the 20Hz signal"? Do you mean that you have a signal that is a 20 Hz sinewave riding on a DC bias (a 20 Hz sinewave added to a constant)?
Regards,
[-Rick-]
xie.qiang wrote:
4/16/2009
Hi Rick,
Sorry for the mis-understanding.
Yes, it's correct, I have a signal riding on a DC bias, and my sampling rate is 192K, by using the DC remvoal filter, it will do remove the DC bias, but it will also attenuate the 20 Hz Signal, is it?
Actually, it is so interested to me is that I have such an application that I want to get the DC bias of my 20 Hz signal.
For example, I want to calculate the RMS value of 10Hz signal of x(n), first multiplied x(n) by it's self get x2(n), [x2(n) = x(n) * x(n) ], and then x2(n) is a 20Hz signal ride on a DC bias, the DC is the RMS value.
One solution is that I can apply a IIR filter to the signal of x2(n), however, it will wait so long time to get the stabe output of IIR.
Since if I can use your DC removal filter, then I can remove the DC bias of signal x2(n), by using the output of DC removal filter y2(n) minus the x2(n), I will finally get the DC (or RMS of 10Hz signal)..
Do you think is it possible?? :-)
Rick Lyons wrote:
4/16/2009
Hello xie.qiang,
before you could use the above DC removal filter you would have to decimate your 192 kHz signal by 400 or 500. (Your 20 Hz signal is far too low in frequency, relative to Fs sample rate, to use the DC removal filter.) You might consider using a high-order decimating CIC filter to extract your DC signal from x2(n). Just a thought.)
Good Luck,
[-Rick-]
xie.qiang wrote:
4/16/2009
Hi Rick,
Thanks your suggestion.
Actually, my singnal to be measured is from 10Hz to 48KHz, it is ture only that the low frequency bother me so much.
Add a Comment
You need to login before you can post a comment (best way to prevent spam). ( Not a member? )
