Simplest Calculation of Half-band Filter Coefficients
Neil RobertsonNovember 20, 20179 comments
Half-band filters are lowpass FIR filters with cut-off frequency of one-quarter of sampling frequency fs and odd symmetry about fs/4  [1]*.  And it so happens that almost half of the coefficients are zero.  The passband and stopband bandwiths are equal, making these filters useful for decimation-by-2 and interpolation-by-2.  Since the zero coefficients make them computationally efficient, these filters are ubiquitous in DSP systems.
Here we will compute half-band coefficients using the window method.  While the window method typically does not yield the fewest taps for a given performance, it is useful for learning about half-band filters.  Efficient equiripple half-band filters can be designed using the Matlab function firhalfband [2].
Coefficients by the Window Method
The impulse response of an ideal lowpass filter with cut-off frequency ωc = 2πfc/fs is [3]:
$$h(n)=\frac{sin(\omega_c n)}{\pi n}, \quad -\infty < n < \infty $$
This is the familiar sinx/x or sinc function (scaled by ωc/π).  To create a filter using the window method, we truncate h(n) to N+1 samples and then apply a window.  For a halfband filter, ωc = 2π*1/4 = π/2.  So the truncated version of h(n) is:
$$h(n)=\frac{sin(n\pi /2)}{n\pi}, \quad -N/2 < n < N/2 $$
Now apply a window function w(n) of length N+1 to obtain the filter coefficients b:
$$b(n)=h(n)w(n), \quad -N/2 < n < N/2 $$
$$b(n)=\frac{sin(n\pi /2)}{n\pi}w(n), \quad -N/2 < n < N/2 \qquad (1)$$
Choice of a particular window function w(n) is based on a compromise between transition bandwidth and stopband attenuation.  As a simple example, the Hamming window function of length N+1 is**:
$$w(n)= 0.54+0.46cos(\frac{2\pi n}{N}),\quad -N/2 < n < N/2 $$
And that’s it!  Equation 1 is all you need to compute the coefficients.  Note that N is even and the filter length is N+1 (odd length).
Examples using Matlab
Here is Matlab code that implements Equation 1 for ntaps = 19:
ntaps= 19;
N= ntaps-1;
n= -N/2:N/2;
sinc= sin(n*pi/2)./(n*pi+eps);      % truncated impulse response; eps= 2E-16
sinc(N/2 +1)= 1/2;                  % value for n --> 0
win= kaiser(ntaps,6);               % window function
b= sinc.*win';
I used the Matlab Kaiser window function b= kaiser(ntaps,beta), where beta determines the sidelobe attenuation in the frequency domain [5].  Higher beta gives better stopband attenuation in the halfband filter, at the expense of wider transition band.  Figure 1 shows the truncated sinc function, the window function, and the coefficients.  Every other coefficient is zero, except for the main tap.  This follows from the fact that every other sample of the truncated sinc function is zero.  The scale of the plot obscures the values of the end coefficients; b(-9) and b(9) are equal to .000526.
Figure 2 shows the magnitude response for fs= 100 Hz, with a linear amplitude scale.  The response of the ideal lowpass filter is also shown.  The amplitude is 0.5 at fs/4 = 25 Hz.  Note the odd symmetry with respect to (x,y) = (25, 0.5).
As already mentioned, ntaps must be odd.  It is possible to create a halfband frequency response with ntaps even, but in that case, there will be no zero-valued coefficients.  Also, for ntaps = 9, 13, … etc, the end coefficients are zero.  For this reason, we should choose ntaps = 4m + 3, where m is an integer.  Thus the useful values of ntaps are 7, 11, 15, etc.  The number of zero coefficients is ½(ntaps-3).
Now let’s look at the response for different values of ntaps (Figure 3).  The upper graph uses a linear amplitude scale, while the lower one uses dB.  As you can see, the stopband attenuation does not change much vs. ntaps, but the transition band becomes sharper as ntaps is increased.  The trade-off between attenuation and transition band can be changed by adjusting the Kaiser window’s beta value.
Footnotes
*  Mathematically, $H(e^{jω}) + H(e^{j(π-ω)})  = 1 $ , where ω = 2πf/fs.
**  If we let n = 0:N instead of –N/2:N/2, the expression for the Hamming window is [4]:
$$w(n)= 0.54-0.46cos(\frac{2\pi n}{N}),\quad  n= 0:N $$
 Figure 1.  Coefficients of Halfband Filter with ntaps = 19
top:  Truncated sinc function     center:  Kaiser window with beta = 6     bottom:  Filter coefficients
Figure 2.  Magnitude response of halfband filter with ntaps = 19, fs= 100 Hz (linear amplitude scale)
Figure 3.  Halfband filter magnitude response for different length filters, fs = 100 Hz
                top:  linear amplitude scale             bottom:  dB amplitude scale
Other DSPRelated.com Posts on Halfband filters
Here are a couple of other posts about halfband filters on DSPRelated.com:
Rick Lyons, “Optimizing the Half-band Filters in Multistage Decimation and Interpolation”, Jan 2016.  https://www.dsprelated.com/showarticle/903.php
Christopher Felton, “Halfband Filter Design with Python/Scipy, Feb 2012. https://www.dsprelated.com/showcode/270.php
References
1.  Sanjit K. Mitra, Digital Signal Processing, 2nd Ed., McGraw-Hill, 2001, p 701-702.
2.  Mathworks website https://www.mathworks.com/help/dsp/ref/firhalfband.html
3.  Mitra, p 448.
4.  Mathworks website https://www.mathworks.com/help/signal/ref/hamming.html
5.  Mathworks website https://www.mathworks.com/help/signal/ref/kaiser.html
Neil Robertson   November, 2017
Appendix  A   Matlab Function for Halfband Filter Coefficients
This program is provided as-is without any guarantees or warranty.  The author is not responsible for any damage or losses of any kind caused by the use or misuse of the program.
%hbsynth.m       11/13/17 Neil Robertson
% Halfband filter synthesis by the window method, using a Kaiser window.
% input argument ntaps must be odd.
function b= hbsynth(ntaps)
if mod(ntaps,2)==0
   error('  ntaps must be odd')
end
N= ntaps-1;
n= -N/2:N/2;
b= sinc.*win';                      % apply window function
Appendix B   Matlab Code to Create Figure 3
%hb_ex1.m    11/13/17 Neil Robertson
fs= 100;
b1= hbsynth(15);
b2= hbsynth(23);
b3= hbsynth(39);
[h1,f]= freqz(b1,1,512,fs);
H1= 20*log10(abs(h1));
[h2,f]= freqz(b2,1,512,fs);
H2= 20*log10(abs(h2));
[h3,f]= freqz(b3,1,512,fs);
H3= 20*log10(abs(h3));
subplot(211),plot(f,abs(h1),f,abs(h2),f,abs(h3)),grid
axis([0 fs/2 -.1 1.1]),xlabel('Hz')
subplot(212),plot(f,H1,f,H2,f,H3),grid
axis([0 fs/2 -80 5]),xlabel('Hz'),ylabel('dB')
text(37,-38,'ntaps= 15')
text(34,-48,'ntaps= 23')
text(23,-52,'ntaps= 39')
Comment by Andreas_RNovember 16, 2018
Hi Neil,
great article ! Do you think that a half band filter designed with this method is suitable for oversampling decimation purposes (low pass filtering oversampled signal).
Thank you !
Andreas
Comment by neiroberNovember 16, 2018
Andreas,
Yes, it is appropriate.  For example, you could use a single HB filter for decimation by 2, two HB's for decimation by 4, etc.  Note in the case of decimation by 4, 8, etc., the stopband frequency range of each stage is different, so the HB filters are not normally identical to each other. See article by Rick Lyons: https://www.dsprelated.com/showarticle/903.php
For decimation by a large factor, a CIC filter may be more appropriate.
regards,
Neil
Andreas,
I should also mention again that the window method does not typically result in the most efficient design; a Parks- McClellan optimizer like Matlab's firhalfband or firpm would be desirable for getting fewest taps.
regards,
Neil
Fantasic, maybe the algorithm is not the most efficient, but it's easy to implement. The other article is also great, obviously the first (downsampling) filter doesn't need many taps in the fir, the last one needs. There are other approaches e.g. overlap/add in the frequency domain. I will give this easy sinc filter a try and will have a look what the performance drop of my synth plug-in is.
This is also very interesting:
https://www.kvraudio.com/forum/viewtopic.php?t=439...
Comment by Andreas_RNovember 18, 2018
Neil, I have implemented the algorithm into my synth plug-in using C++, optimized it and tested a lot of FIR tap sizes using the great online designer here: https://fiiir.com/ and looking at the frequency response of my software at different sampling rates. I'm now using 7, 11 and 15 taps (in case of 8 x downsampling) and it seems that this is enough for my purposes. It filters the most portions of a) generated gaussion noise aliasing and b) distortion/overdrive effect aliasing. I come to the conclusion that I have a performance drop of 6-10% in comparison to the other synth functionality. For what it does, that's a moderate value but I'm thinking about additional optimizations. Another remark is, that every second tap value should really be 0 (instead of very very small float/double values). Modern CPUs seem to automatically "skip" multiplications by 0., my performance profiling showed that.
I should add that the 6-10% performance drop was measured with an easy synth patch, with more complex patches and more polyphonic voices, the drop is about 2-3%.
Comment by neiroberNovember 18, 2018
Andreas,
Good work!  Thanks for the link.
regards,
Neil
Comment by hitdshu1993September 11, 2019
Very intuitive and good tutorial. Thanks very much.
Comment by neiroberSeptember 11, 2019
You're welcome!
