Is it possible to restore audio that has been tonally modified by a phase vocoder?
Started by gabrielg 7 years ago2 replieslatest reply 7 years ago207 views
My objective is to apply some process to the modified audio that allows me to obtain the original audio. I think it can be solved through machine learning techniques. I don't know if there is any method or algorithm that solves it. I appreciate any information, pappers, etc. Regards
Reply by nelsonaOctober 15, 2019
Hello Gabriel,
You may want to wait for more experienced posters to chime in, but I believe the answer to your question is no.
If the process applied to the audio has a mathematical inverse, then the answer would be yes.
I'm not an expert on phase vocoders, but I don't believe a phase vocoder has a mathematical inverse (in the general case).
As for using machine learning, I don't think that will help you either.
Best of luck,
Nelson
Reply by enahmadOctober 15, 2019
Tone modification in a phase vocoder uses time-scaling in the synthesis stage. Time-scaling works by using phase information to estimate the correct frequencies. The modified signal does not have a mathematical inverse anymore, but one can still get an approximate inverse.
If you want to undo the modified signal, bear in mind that you will need again to estimate phase information. It may be done, but as phase error is accumulated the coherence is lost. A clear way to notice the loss of coherence is in the transients: note attacks will smear out and lose their natural sound. The same will happen with the harmonic partials of one note.
If your signal consists only of voice, you might get a reasonable result; no so much for music.
Hope that helps.
   Eduardo
