Problem with 1st order Massberg LPF
Started by jtp_1960 7 years ago3 replieslatest reply 7 years ago188 views
I'm trying to implement this filter in title by following the book "Designing Audio Effect Plug-Ins in C++" By Will Pirkle
Problem I'm facing is the magnitude response error when comparing against analog model of the LP filter. Here is a plot showing the difference:
I get these are values for variables (fc=1000, fs=44100):
>> massberg_test
    w0 =  0.14248
    g1 =  0.045305
    gm =  0.70711
    wm =  6283.2
    Om =  0.071359
    Os =  0.10081
    g0 =  1.1008
    a0 =  0.14612
    a1 =  0.055508
    b1 = -0.89919
Real:
    a = [ 0.132736  0.050424 ]
    b = [ 1.00000  -0.81684 ]
I don't have access to the original paper by M. Massberg so, I can't be sure if the equations in my source book is correct (I've read that the "ac" in g1 formula is just a typo and book errata does not mention other errors for this fileter).
Q:
1. Are the equations found in Pirkle book correct?
2. If 1 is Yes then where to look the issue from?
Reply by MichaelRWAugust 24, 2018
I think the value for Omega_s is not correct.  The value that I get is 0.07121.  Since the "b0", "b1", "a0", and "a1" coefficients are computed using Omega_s then they are incorrect too.
Using the equations in the body of the text from the Massberg (2011) paper,
fc=1e3;
Fs=44.1e3;
Wn=2*pi*fc/Fs;
g1=2/sqrt(4+(Fs/fc)^2);  % Okay
gm=max(sqrt(0.5), sqrt(g1));  % Okay
wm=2*pi*fc*sqrt(1-gm^2)/gm;  % Okay
Om=tan(wm/(2*Fs));  % Okay
Os=Om*sqrt((gm^2-g1^2)*(1-gm^2))/(1-gm^2);  % Check
b0=Os+g1; b1=Os-g1;
a0=Os+1; a1=Os-1;
b=[b0/a0 b1/a0];
a=[1 a1/a0];
     figure; freqz(b, a, 4096, Fs);
[bf, af] = lp1(Wn);
     figure; freqz(bf, af, 4096, Fs);
The Matlab code from the Massberg (2011) paper for the first-order lowpass filter is,
function [b,a] = lp1(Wn)
g1 = 2/sqrt(4+(2*pi/Wn)^2);
gm = max(sqrt(0.5),sqrt(g1));
Ws = tan(Wn*sqrt(1-gm^2)/(2*gm)) *sqrt((gm^2-g1^2)*(1-gm^2)) /(1-gm^2);
b0 = Ws+g1;
b1 = Ws-g1;
a0 = Ws+1;
a1 = Ws-1;
b = [b0/a0 b1/a0];
a = [1 a1/a0];
where Wn is,
Wn=2*pi*fc/Fs;
Reply by jtp_1960August 24, 2018
Thanks a lot, you're right. This change fixes the problem.
Very good.  I'm glad to have helped.
