Generating Noise
Started by naumankalia 8 years ago4 replieslatest reply 8 years ago273 views
Hello all
I need to generate random white Gaussian noise of some x second length. I also need to add multiple sinusoidal pulses of y (y<<x) duration and SNRs of a dB, b dB and c dB respectively at random locations in x sec length Gaussian noise.
Can any one kindly help me ?
Also how can i verify the results i.e. the required SNR has been generated?
Reply by cogwsnFebruary 5, 2018
Reply by naumankaliaFebruary 5, 2018
Hi
Thanks for helping material.
Hi cogwsn
The article is clear in case of single pulse as i understand it. As i have to insert multiple pulses at different locations with different SNRs, should i repeat the 4 steps mentioned in article separately for all pulses and then simply add them together?
Well in that case :
Suppose your signal chunks are X1, X2, X3, ....Xn and your SNR requirement is SNR_dB1, SNR_dB2, SNR_dB3, .... SNR_dBn
You do as :
 Y1 = add_awgn_noise(X1,SNR_dB1);
 Y2 = add_awgn_noise(X2,SNR_dB2);
 Y3 = add_awgn_noise(X2,SNR_dB3);
 Yn = add_awgn_noise(X2,SNR_dBn);
And finally you concatenate Y1, Y2, Y3, .... Yn.
