Differential encoder simulation
Started by simonzz 7 years ago7 replieslatest reply 7 years ago134 views
I am studying the following differential encoder:
where the quantizer is defined as \( Q(y) = \text{sgn}(y) \)
and I would like to be sure I understand it correctly, because I have a few doubts.
The analysis I do is the following:
\(\begin{aligned}
\tilde{y}(n) & = Q(y(n))\\
y(n) & = x(n) - a(n-1)\\
a(n) &= \tilde{y}(n) + a(n-1)\\
& = \tilde{x}(n) - a(n-1) + a(n-1)\\
& = \tilde{x}(n)\\
a(n-1) & = \tilde{x}(n-1)
\end{aligned}\)
so if I invent a sequence to be coded, e.g.
\( x(n) = \{0.4,\,0.7,\,1,\,-1.7\}\)
I obtain the following table:
\( \begin{array}{| c | c | c | c | c |}\hline
n & 0 & 1 & 2 & 3 \\ \hline
x(n) & 0.4 & 0.7 & 1 & -1.7 \\\hline
a(n) & 1 & 0 & 1 & 0 \\\hline
a(n-1) & 0 & 1 & 0 & 1 \\\hline
y(n) & 0.4 & -1.3 & 1 & -2.7 \\\hline
\hat{y}(n) & 1 & -1 & 1 & -1 \\\hline
\end{array} \)
From the above table I obtain \(a(n) = 0 \) for some values of \( x(n) > 0 \) (e.g. when \(n = 1\))
If \( a(n) = \tilde{x}(n) = Q(x(n)) \) I suppose it should imply that \(a(n) \neq 0 \) if \( x(n) > 0 \).
So, is there something wrong in my analysis ?
Thank you in advance.
Simon
Reply by jeff_burchOctober 13, 2017
Can you elaborate on how you made this substitution?
Where did "x bar" come from?
It looks like my copy/paste isn't working. I've got a question about your substitution: "x-bar"(n) - a(n-1) + a(n-1)
Where did "x-bar" come from?
Reply by simonzzOctober 13, 2017
Hello @jeff_burch,
You are right. I did not specified it.
I use \(\tilde{x}(n)\) to represent the quantized value of \(x(n)\).
So \( \tilde{x}(n) = Q(x(n)) \).
Simon
Simon,
I think the problem is an incorrect block diagram manipulation. Take your drawing and assume that Q is a linear operator (it isn't, more on that later). You can rework the drawing and place Q to the left and also below the summation point where X[n] enters the drawing. So, your modified drawing would have two Q blocks (both before the summation point).
Let's focus on this second Q block that is in the path between a[n-1] and the summation point. I bet you have assumed that this second Q is superfluous because a[n-1] is already quantized, so you've dropped it from your analysis.
I think you can only legally move Q around like this when it is a linear operator. Because Q is sgn() (i.e. non-linear), I don't think you are allowed to move it around like this.
So, I think you are going astray when you introduced "x-bar" into your equations above. I think you want to make this substitution:
a[n] = sgn( x[n] - a[n-1] ) + a[n-1]
I don't think this can be simplified further. I don't think you can legally distribute the sgn( ) function:
sgn( x[n] - a[n-1])  != sgn( x[n] ) - sgn( a[n-1])
Note, I agree with you that sgn( a[n-1] ) is = a[n-1] but I think the != is still true.
Cheers, Jeff
Of course I agree with you. This was another little doubt I had.
Thank you Jeff.
Simon
Reply by oliviertOctober 13, 2017
Typically when a[n-1] = 1, then the sgn(x[n]-a[n-1]) will be negative for x[n] less than 1.
so for x[n] = 0.7 and a[n-1] = 1, sgn(x[n]-a[n-1]) = -1 even if x[n] is positive.
Thank you too @oliviert.
Simon
