Goertzel algorithm
Started by flutekick 9 years ago4 replieslatest reply 9 years ago522 views
For Goertzel algorithm, does it require N+1 or N samples to generate the bin corresponding to N-point DFT?
In Rick's book I see the following statement "For the Goertzel algorithm we retain only every Nth, or (N+1)th,". I am not sure why it "N+1 or N". Could someone please clarify?
Krishna
Reply by TavassoliAugust 23, 2017
The Goertzel difference equations are
w(n)=2cos(2\pi m/N) w(n-1) - w(n-2) + x(n)
y(n)=w(n) - e^(-j2 \pi m/N) * w(n-1)
To find X(m), we need to calculate y(N), so we should find w(N) and w(N-1). Then the first equation should be evaluated N+1 times (assuming that the samples of x(n) start from index n=0 to n=N-1). However, if we are looking for the abs(X(m))^2, we can obtain the following equation from y(n) given above
abs(X(m))^2 = w(N-1)^2 + w(N-2)^2 - w(N-1)*w(N-2)*2*cos(2* \pi *m/N)
this is equation (13-83) of the book. Now, using this equation, we need to evaluate the w(n) equation by N times.
Figure 13-44 shows an example with N=64, for X(15) and abs(X(15)) the first stage should be evaluated by 65 and 64 times, respectively.
Please verify and correct me if I am making any mistake.
Reply by flutekickAugust 23, 2017
Thanks Tavassoli.
I am just wondering if DFT/FFT and Goertzel evaluates the same bin, why should Goertzel depend on additional sample?
DFT/FFT and Goertzel are different methods to calculate the same thing and Goertzel does not need any additional input sample. When we evaluate w(n) equation N+1 times, we are considering x(N)=0 as explained on page 530 of Rick's book and we are not using any new sample. (To see why x(N) should be set to zero, review the proof of the algorithm. To derive a convolution from DFT equation we have to assume x(n)=0 for n<0 and n>=N).
-Mahdi
Reply by Tim WescottAugust 23, 2017
I couldn't tell you exactly how without wrapping myself in math for a while, but if you mind your p's and q's you should only need \(N\) points.  Get the math right and the Goertzel has the exact same effect as doing a one-bin FFT (you can even extract both inphase and quadrature parts -- if you get the math right).
Note that I don't like the Goertzel algorithm:  It was a great thing when memory and multipliers were expensive, but the places where it's really advantageous today is an ever-shrinking set of applications.  We're at the point now where you can get a Cortex M0 part in a 16-pin package 3mm on a side, for less than $1 each in modest quantities.  You can buy a whole bunch of processors for the difference in engineering time between writing quick robust inefficient code that works on an M0 vs. shoe-horning the same functionality into some 8-bit thing.
