Filtering of amplitude spectrum
Started by bachhavpramod 9 years ago7 replieslatest reply 9 years ago506 views
I want to perform moving average on the amplitude spectrum of a speech signal frame (abs(fft(sig))) in the particular frequency range (e.g. 4-8kHz, Fs=16kHz). In other words, I want to smooth the amplitude spectrum in the desired frequency range. How can it be performed?
Reply by Tim WescottApril 21, 2017
Do you really want to perform a moving average on the amplitude, as opposed to performing a moving average on the signal itself?
If the answer is yes, then just multiply the signal by a sinc signal of appropriate width, point-by-point, before taking the FFT.
If the answer is "on reflection, I'm not sure if I know what I'm doing" then tell us the result you're trying to achieve (low pass filtering of your signal, better spectral display, whatever), and we'll suggest methods.
Reply by bachhavpramodApril 21, 2017
Thanks for your answers.
Here I am displaying what I am trying to achieve.
Blue plot shows the magnitude spectrum of a speech frame with Fs=8kHz after zero insertion in time domain, a kind of upsampling. I want to smooth the spectrum in the range 4-8kHz (as shown by grey plot). The grey plot is randomly drawn for an illustration. Not sure if its possible to do it but I want to try some experiments this way.
Reply by probbieApril 21, 2017
In that case, as has been suggested, you need to apply a moving average filter to the data points you are collecting (assuming that the source of the curve you have illustrated is indeed from discrete data points). Sometimes, it is useful to smooth frequency response data on a log scale, which them results in fractional octave smoothing, which you may wish to google.
Reply by JOSApril 21, 2017
For this I would use a "zero-phase" smoother (such as a moving average symmetric around its midpoint) on the COMPLEX spectrum, and then form the magnitude.
Note that doing this effectively shortens your "window" in the time domain.  For example, the spectral-smoother (1/4, 1/2, 1/4) corresponds to a zero-phase Hann window in the time domain (when there was no zero-padding).
Thanks!
I will try to follow the suggestions so far for the implementation.
It would be helpful if I could know any book or a paper that I can refer for more details.
Reply by fernandoorgeApril 21, 2017
What do you mean with "smooth"?
In case you want to eliminate the upper-band of the spectrum, filtering the signal in the time domain should be enough.
But in case you want to eliminate random noise to get a "better" spectrum of the speech signal, maybe you should take not a simple fft approach but a spectral estimation approach.
Depending on how much available data you have, there are many different approaches for the estimation of the speech signal spectrum. (e.g. Welch's Method, Blackman-Tukey Method, etc.)
Reply by dgshaw6April 21, 2017
What about the spectrum do you not like that makes you want to smooth it?
Remember, that the spectrum of speech is always very dynamic and rough when comparing across the frequency range.
If you really do want to even out the spectrum from bin to bin, then my best recommendations is to use a median filter.  Pick an odd number (say 5, 7, 9) for a window length, then run the window over the magnitudes of the various bins that it spans.  Assign to the middle bin of the window the median value of the magnitudes spanned by the window.
Do this for each bin one at a time.  Special care needs to be taken as you work with bins that are less than half the length of the window from end of you spectrum.  Not usually a problem, because speech most often has little content at the spectral ends.
I don't recommend a exponential running average. Exponential averaging will influent the current bin values by only the ones on the left or right depending on your starting end.
One last comment.  You cannot easily do this in place, or you will be averaging new bins with the averages that you just calculated.
