I came across this process when working on a wireless communication project where the whitening process is applied before we do signal detection, but I found little clue why we need to do this. Most of the text book/online material explains "how" to do so but gave little insight on "why". Can someone explain what is the significance of doing so before signal detection and what is the consequence if we skip this stage?
william
Reply by jithinrjFebruary 12, 2017
From what I know, the received signal in wireless system is y=hx + n. where n is complex gaussian white noise. After applying equalization, y* = y/h = x + n/h. The noise n/h is now no longer white but 'coloured' as the Power spectrum is not flat now. The ML decoding cannot be applied now since noise is not white. In order to compensate for this, we apply whitening on the noise so that ML decoding can be applied.
Reply by JOSFebruary 12, 2017
Many detection and estimation formulations assume that the added noise is white (see "minimum variance" and "maximum likelihood" estimation).  When the noise is not white, we generally try to flatten its spectrum as much as we can, pushing its correlation closer to white. See https://en.wikipedia.org/wiki/Generalized_least_sq...
Reply by weilun731February 12, 2017
but when we do whitening on "signal + noise", wouldn't we skew the signal to be detected as well? I am looking for what the side effect this could cause... (The whitening matrix is calculated from the time duration when we have "reference signal + noise" and it is then applied to the later time duration when we have " data signal+noise" before signal detection.)
Yes, only the noise should be whitened.  In audio, we typically use segments of silence to form a noise-floor estimate.  Otherwise, you can try to preserve the spectrum where there is signal (i.e., don't whiten there).  In sinusoidal modeling, we sometimes extrapolate the noise across the gaps created by "removing" sinusoidal peaks to get a noise-floor estimate ("sines plus noise synthesis").
Reply by Tim WescottFebruary 12, 2017
Sounds like some variation of Wiener filtering or something based on the same notions, or maybe equalization.  Are you running the signal through a matched filter after whitening?
no there is no matched filter involved later. The whitening matrix is calculated from the time duration when we have "reference signal + noise" and it is then applied to the later time duration when we have " data signal+noise" before signal detection (using soft decision).
If the reference signal is adjusted to be spectrally white that might make sense -- in that case the "whitening matrix" would probably be a decent equalizer.
