Python (numpy) to Matlab/Octave conversion problem
Started by jtp_1960 4 years ago4 replieslatest reply 4 years ago252 views
I'm new to python language. I can't figure out what happens here in code:
def evaluate(self, x):
        p1 = 1
        p2 = np.zeros((1, self.r), dtype=self.dtype)
        p2 += self.coeff[0, np.newaxis, :]
        for k in range(1, self.n):
            v = x - self.xcoord[k-1]
            p1 = v*p1
            p2 += p1[:, np.newaxis] * self.coeff[k]
        return p2
where,
n = array size of xcoord
r = self.ycoord.shape
coeff = np.zeros((self.n+1, self.r), dtype=self.dtype)
How these
and
p1[:, np.newaxis]
can be converted to Matlab/Octave language ?
p1 is defined as variable but, then later it is used as an array type variable. coeff is an array type variable ... but, what is done in command
Reply by omersayliJune 21, 2022
In NumPy,
np.newaxis
is used to add 'dimension' to the vector or matrix.
The * is used for one-to-one multiplication of elements (not matrix product). I guess 'np.newaxis' is used to have matching matrix dimensions
Reply by jtp_1960June 21, 2022
Yes, it looks like np.newaxis does not (in these cases) change the dimensions so, the function can be converted to Matlab/Octave language as like:
 % evaluation
  p1 = 1;
  p2 = zeros(1, 1);
  p2 += coeff(1);
  for k = 1:n
    v = x - xcoord(k);
    p1 = v*p1;
    p2 += p1 * coeff(k+1);
  endfor
means
p2 = p2 + p1[:, np.newaxis] * self.coeff[k]
I'm C++ developer mainly so that is std syntax ... I'll edit the question a bit.
