Can you find the illegal step?
Started by Rick Lyons 5 years ago10 replieslatest reply 5 years ago368 views
Can you find the illegal step in the following silly proof? Given: a=b
$$ a^2=ab$$
$$a^2-b^2 = ab-b^2$$
$$(a+b)(a-b)=b(a-b)$$
$$a+b = b$$
$$b+b=b$$
$$2b=b$$
Reply by CharlieRaderAugust 29, 2021
Reply by philipoakleyAugust 29, 2021
This is mathematics, not real world, isn't it?
The error, if there is one ;-), is the last step where 'b' should be subtracted from both sides, resulting in the true answer 'b=0; => 0=a', !
See also: dy/dx => $inf * 0, doesn't it?
(Hence, Are there more infinitesimals than infinities?)
Thinking outside the box ;-)
Reply by Rick LyonsAugust 29, 2021
OK OK, the above problem was pretty easy. Can you find the illegal step in the following?
Theorem: 4=5
Proof:
$$16-36=25-45$$
$$4^2–9*4=5^2–9*5$$
$$4^2–9*4+81/4=5^2–9*5+81/4$$
$$ (4-9/2)^2=(5-9/2)^2$$
$$4-9/2=5-9/2$$
$$4=5$$
Reply by PlatybelAugust 29, 2021
Thanks for the mental challenge.  It is tricky. The illegal step is taking only one solution from each side when taking the square root.  There are two factors on each side of the equation.
Reply by adiduaAugust 29, 2021
If $x^2 = y^2$, taking square root on both sides gives $x = +/- y$. In this case accepting the solution $x = -y$ would not have caused a contradiction.
Alternatively,
$x^2 = y^2$, implies $(x+y)(x-y)=0$, so either $x=y$ or $x=-y$ or both. Given the specific values of $x$ and $y$ in this problem, we know that $x=y$ is not true, so we must have $x=-y$.
Going from step 3 to step 4, you divided by (a-b). Division by 0 is not meaningful.
Reply by neiroberAugust 29, 2021
If you let b = 1, then you get the "classic" homework result:
2 = 1
From this follows the other classic result:
1 = 0.
As a corollary, 2 = 0.
Reply by SarabethAugust 29, 2021
Like CharlieRader said, division by 0 is the truly "illegal" step, but to my mind, the worst decision is not factoring out common terms until step 3. The error between steps three and four becomes obvious if the first transformation is to reduce the initial equation to a = b, which also makes the multiplication by zero in step three apparent.
Reply by cortegaAugust 29, 2021
3rd step into 4th is only correct if a!=b, but the condition was a=b,
therefore proof is inconsistent
