Setting required FFT spectrum bandwidth w.r.t the Sampling rate
Started by Nukul13 5 years ago4 replieslatest reply 5 years ago497 views
I am working on an accelerometer with sampling rate of 26.7 kHz on which I intend to calculate FFT. Hence the FMax =  (26.7/2.56 = 10.4kHz). As I am performing this on a microcontroller, I have a limitation that I can only compute 2048-point FFT where my LOR(Lines of Resolution) is 2048/2.56 = 800.
Now the problem is that my deltaF = 10400/800 = 13Hz, which is a very low resolution hence I cannot go ahead with this solution.  Also my requirement is to calculate FFT upto 1 kHz where my deltaF will be 1000/800 = 1.25Hz, which is acceptable to me.
So is it possible to reduce FMax of my spectrum from 10.4 kHz to 1 kHz with the abovementioned sampling rate of the sensor?
FYI,
The sensor has an inbuilt LPF which I can implement at 1 kHz.
#FFT
Reply by dgshaw6July 23, 2021
If you only care about signals up to 1kHz, you can filter and decimate the sample data down to a lower rate, and then run 2048 point FFTs on the lower sampling rate output.
If you decimate by 4, then your resulting data will be sampled at 10.4k/4 = 2.6 kHz.  A 2048 point FFT will give you bin resolution of 1.26953125 Hz.
Hope this is a useful idea.
If your input data are already filtered by a 1 kHz LPF, then you could just throw away 3 out of every 4 samples, and then do the 2048 point FFT.
Reply by Y(J)SJuly 23, 2021
Why do you want to compute an FFT? Do you really need the entire spectrum?
If you only need the spectrum in a known area you can perform a zoom-FFT which has much higher resolution there.
If you only want to find the most significant component frequencies, then FFT is a really bad idea. Will a max entropy or Pisarenko (PHD) work for you? For a small number of lines they are efficient and give much higher resolution (dependent on SNR not on bin size).
Reply by chalilJuly 23, 2021
Hi,  you can try ZoomFFT or CZT (chirp z-transform) which can do DFT from f1 to f2 with higher resolution. Hope it helps.
Chalil
Reply by Moldy01July 23, 2021
Maybe take a look at the Constant Q transform. You decide number of bins, frequencies involved, etc...  often used for music because of the specificity of frequencies and musical tones needs.
Just a thought
