Joint Research in Base Band Signal Processing
Started by Mannai_Murali 5 years ago4 replieslatest reply 4 months ago300 views
With in a month I will start doing research on Signal Processing related to Receiver Design (Mainly related to one or more of Synchronization (Frequenbcy Offset/Sampling Clock Offset),Channel Estimation,Equalization,ICI mitigation for single carrier as well as OFDM.Is anybody is interested to do joint research with me.To know more about me look for 'Vaidyanathaswami Muralidharan' at linkedin.
I have a Master Degree in Communication Engineering and working experience .I am a freelancer.
I have worked in US.I live in India.
No financial liabilities from either side.The purpose is to jointly publish research papers.
Mannai_Murali@hotmail.com
Reply by fharrisMay 25, 2021
mannai, start looking for papers by fred harris. One of my specialties in synchronization.
also look for the 3rd edition id the sklar-harris book, Digital communications.
we have a new chapter on synchronization...
there is also a chapter on synchronization in my Multirate Signal processing book, 2-nd edition now out for two months
read the attached papers too.
Lets_assume_System_synchronized_2.pdf
WPMC_2010_BE_Filters_5 .pdf
I can send you more papers, just don't have space to attach them
try fjharris@ucsd.edu
best regards
Reply by Aida92May 25, 2021
Hello Fred H
Could you please send these papers to ani.kom1920@gmail.com?
Thank you in advance!
Have a nice one!
Anna
Reply by Mannai_MuraliMay 25, 2021
Thank you Fred Harris.I will look in to them.
Reply by wuwywFebruary 2, 2026
Prof. Harris,
I’m reading your work on carrier synchronization and symbol-timing synchronization and wanted to ask one direct question:
Do these synchronization methods apply to OFDM receivers? If yes, which parts transfer directly; if not, what are the key modifications needed
