NLMS code (simple question)
Started by Artur1988 6 years ago7 replieslatest reply 6 years ago286 views
Hi all,
I'm implementing a NLMS filtering code and I'd like to confirm if I'm doing the right thing.
I'm evaluating the basic iterative equations (boldface for vectors, ^T for transposition, L for the order and n the iterations):
w(n) = w(n-1) + mu * x(n)^T * e(n)
e(n) = d(n) - x(n)*w(n-1)
x(n) = [x(n) x(n-1) ... x(n-L+1)]^T
by means of a for-loop that goes from n=L until n=length(d), after initializing all variables with zeros.
My supposition is that the first computation of x(n) occurs when n=L. Is it correct?
Also, I was wondering if I should initialize the error vector with:
e(1:L-1) = d(1:L-1)   -> the change I probably have to make
instead of
e(1:L-1) = 0             -> the way my code currently works
Any help is appreciated.
Thanks in advance.
Best regards,
Artur
Reply by andrewstanfordjasonApril 23, 2020
I typically do this the other way around, i.e.
e(n) = d(n) - x(n)*w(n)
w(n+1) = w(n) + mu * x(n)^T * e(n)
Then there is no need to initialise the error vector.
You can wait for n to equal L but it shouldn't be necessary.
Reply by Artur1988April 23, 2020
Thanks for your feedback, andrewstanfordjason.
Considering the sequence of equations that you proposed, what is the range for n?
Are you asking if n starts at zero? If so then yes. I would typically define negative x(i) = 0 (i.e. initialise x(0) to be zero)
OK, perfect. Thanks!
Reply by MichaelRWApril 23, 2020
NLMS or LMS?
In this case, I'm implementing NLMS.
So mu = mu0 / (epsilon + var(u)*L),
where var(u) is the input signal variance, L is the order and epsilon is the regularization parameter (I set it as equal to 0.1).
Okay, very good.  A different formulation that I haven't seen:  variance in place of inner-product of tap input vector.
