A New Contender in the Digital Differentiator Race
This blog proposes a novel differentiator worth your consideration. Although simple, the differentiator provides a fairly wide 'frequency range of linear operation' and can be implemented, if need be, without performing numerical multiplications.
Background
In reference [1] I presented a computationally-efficient tapped-delay line digital differentiator whose $h_{ref}(k)$ impulse response is:
$$ h_{ref}(k) = {-1/16}, \ 0, \ 1, \ 0, \ {-1}, \ 0, \ 1/16 \tag{1} $$and whose $ \lvert H_{ref}(\omega) \rvert $ frequency magnitude response is shown by the blue dashed curve in Figure 1.
Figure 1: Normalized frequency magnitude responses of
the reference [1] differentiator, and a
central-difference differentiator.
For comparison purposes, Figure 1 shows the frequency magnitude response of the popular central-difference differentiator (green dotted curve), $ \lvert H_{cd}(\omega) \rvert $, whose $h_{cd}(k)$ impulse response is:
$$ h_{cd}(k) = 1/2, \ 0, \ {-1/2}. \tag{2} $$In Figure 1 we see the $ \lvert H_{ref}(\omega) \rvert $ response's increased 'frequency range of linear operation' compared to the $ \lvert H_{cd}(\omega) \rvert $ frequency magnitude response. That's the primary benefit of the $h_{ref}(k)$ differentiator.
The response curves in Figure 1 are what I call "normalized" magnitude responses. I'll define what I mean by normalized later in this blog.
(As a bit of trivia, it's interesting to note that the central-difference differentiator's magnitude response is equal to the first half cycle of a sine wave. I prove that fact in Appendix A.)
The Proposed Differentiator
The improved differentiator I propose here has the impulse response given by:
$$ h_{pro}(k) = {-3/16}, \ 31/32, 0, \ {-31/32}, \ 3/16 \tag{3} $$and whose $ \lvert H_{pro}(\omega) \rvert $ frequency magnitude response is shown by the black solid curve in Figure 2.
Figure 2: Normalized frequency magnitude responses of
the proposed differentiator, the reference [1]
differentiator, and a central-difference
differentiator.
Figure 2 shows the benefit of the proposed $ h_{pro}(k) $ differentiator. Its $ \lvert H_{pro}(\omega) \rvert $ response has an increased-width (by roughly 33%) 'frequency range of linear operation' compared to the $ \lvert H_{ref}(\omega) \rvert $ frequency magnitude response. Based on Figure 2, the $ h_{pro}(k) $ differentiator should be useful in applications where the spectral components of the input signal are less than $ \pi/2 $ radians/sample $ (f_s/4 \ Hz.) $
The $ h_{pro}(k) $ differentiator has, due to its antisymmetrical coefficients, linear phase in the frequency domain. In addition, the differentiator's input/output time delay (group delay) is exactly two sample periods. Having a delay that's an integer number of samples makes this differentiator useful when its output must be synchronized with other time-domain sequences, such as in FM demodulation applications.
Proposed Differentiator Implementation
The traditional tapped-delay line implementation of the proposed differentiator is shown in Figure 3(a). A folded delay line implementation reducing the number of computations from four multiplications to two multiplications per output sample is given in Figure 3(b). And a folded multiplier-free implementation is shown in Figure 3(b) where multipliers are replaced by binary right-shift operations. In that figure the 'BRS,x' nomenclature means a binary right shift by x bits.
Figure 3: Proposed $ h_{pro}(k) $ differentiator implementations:
(a) traditional implementation; (b) folded
implementation; (c) folded multiplier-free
implementation.
Differentiator Gains and Normalized Magnitude Curves
For completeness I mention that the $ h_{ref}(k) $ and $ h_{pro}(k) $ differentiators have magnitude response gains greater than unity. This is shown by the actual frequency magnitude responses shown in Figure 4.
To explain what I mean by "gain", notice how the slope of the central-difference differentiator's $ \lvert H_{cd}(\omega) \rvert $ response (green dotted) curve is unity at low frequencies in Figure 4. Thus I claim the gain of the $ h_{cd}(k) $ differentiator has a gain of one. The slope of the reference [1] differentiator's $ \lvert H_{ref}(\omega) \rvert $ response (blue dashed) curve is 1.63 at low frequencies and the slope of the proposed differentiator's $ \lvert H_{pro}(\omega) \rvert $ response (black solid) curve is 1.2 at low frequencies. So I claim that the $h_{ref}(k)$ reference [1] and $ h_{pro}(k) $ proposed differentiators have gains of 1.63 and 1.2 respectively.
Figure 4: Actual frequency magnitude responses of
differentiator.
Those actual magnitude response curve in Figure 4 prevent us from comparing the 'frequency ranges of linear operation' of the various differentiators. So to make that comparison I divided the Figure 4 $ \lvert H_{ref}(\omega) \rvert $ response sample values by 1.63 to create the normalized blue dashed curves in Figures 1 and 2. Likewise, I divided the Figure 4 $ \lvert H_{pro}(\omega) \rvert $ response sample values by 1.2 to create the normalized solid black curve in Figure 2.
A Digital Differentiator Clarification
When thinking about digital differentiators it's useful to be aware of the algebraic form of their time-domain difference equations. For example, let's assume that $ y(n) $ represents a central-difference derivative of an $ x(n) $ sequence. The correct estimation of the $ y(n) $ derivative of an $ x(n) $ is:
$$ \text{estimated derivative of } x(n) = y(n) = {{x(n) - x(n-2)} \over {2t_s}} \tag{4} $$where $ t_s $ is the time between the $ x(n) $ samples measured in seconds. (Variable $ t_s $ is the 'dt' in a generic differentiator's dx/dt derivative.)
Often in the DSP literature, for convenience, the time between $ x(n) $ samples is assumed to be unity, i.e. $ t_s = 1 $ and a central-difference differentiator's difference equation takes the popular form of:
$$ y'(n) = {{x(n) - x(n-2)} \over 2} . \tag {5} $$Computing Eq. (5)'s estimated $ y'(n) $ derivative is acceptable in many applications because $ y'(n) $ will always be proportional to Eq. (4)'s $ y(n) $. But to be dimensionally correct, Eq. (4)'s $ y(n) $ should be computed, rather than Eq. (5)'s $ y'(n) $.
For example, let's say the continuous red-dotted curve in Figure 5 is the $ x(t) $ instantaneous water pressure inside a water pipe measured in pounds per square inch (psi). And we have three $ x(n) $ samples of $ x(t) $ shown by the large $ x(n) $ black dots. The $ t_s $ time between sample is 0.5 seconds.
Figure 5: Digital differentiator example. Estimating the
slope, $ dx(t)/dt $, of the continuous $ x(t) $ signal
by way of digital differentiation of the
sampled $ x(n) $ sequence.
To estimate the rate of pressure change at time instant two seconds $ (4t_s) $ once sample $ x(5) $ is available, using Eq. (5) gives us a $ y'(5) $ value of:
$$ y'(5) = {{x(5)-x(3)} \over 2} = {{10 \ psi - 5 \ psi} \over 2} = 2.5 psi. $$However, time rate of pressure change values must dimensionally be psi/second.
What we should do is use Eq. (4) giving us a dimensionally-correct time rate of pressure change value of:
$$ y(5) = {{x(5) - x(3)} \over {2t_s \ seconds}} = {{10 \ psi - 5 \ psi} \over {1 \ second}} = 5 \ psi/second. $$Result $ y(5) $ tells us the water pressure increased by 5 psi during the one-second time interval from 1.5 seconds to 2.5 seconds. So my point is, Eq. (5)'s $ y'(n) $ is the popular form of a central-difference differentiator's difference equation, but Eq. (4)'s $ y(n) $ expression is the dimensionally-correct form.
References
[1] http://www.dsprelated.com/showarticle/35.php
Appendix A: Proof of Cent-Diff Differentiator's Sinusoidal Magnitude Response
The proof that a central-difference differentiator's magnitude response is equal to the magnitude of a sine wave proceeds as follows: With the differentiator's time-domain impulse response being $ h_{cd}(k) = [1/2, \ 0, \ -1/2] $, its z-transform is
$$ H_{cd}(z) = {{z^{-0} - z^{-2}} \over 2} . \tag{A-1} $$Multiplying Eq. (A-1) by $ z/z $ gives us a new, and equivalent, z-transform of:
$$ H_{cd}(z) = {1 \over z}{{z^{1} - z^{-1}} \over 2} . \tag{A-2} $$Replacing $ z $ with $ e^{j\omega} $ gives us the differentiator's frequency response of:
$$ H_{cd}(\omega) = {1 \over {e^{j\omega}}}{{e^{j\omega} - e^{-j\omega}} \over 2} . \tag{A-3} $$Knowing that $ (e^{-j\omega} -e^{-j\omega})/2 = jsin(\omega) $, we write:
$$ H_{cd}(\omega) = {j \over {e^{j\omega}}}[sin(\omega)] = {{e^{j\pi/2}} \over {e^{j\omega}}}[sin(\omega)] . \tag{A-4} $$Therefore the $ \lvert H_{cd}(\omega) \rvert $ frequency magnitude response is equal to the magnitude of a sine wave as:
$$ \lvert H_{cd}(\omega) \rvert = \left\lvert\frac{e^{j\pi/2}}{e^{j\omega}}[sin(\omega)]\right\rvert = \left\lvert {e^{-j(\omega-\pi/2)}[sin(\omega)]} \right\rvert = \lvert sin(\omega) \rvert . \tag{A-5} $$You might also like
- Comments
perhaps you didn't take into account the 'normalization' that I described in my blog. Try the following MATLAB code and if you're still having problems please let me know.
[-Rick-]
clear
h_CentDiff = [1, 0, -1]/2;
h_Prop = [-3/16, 31/32, 0, -31/32, 3/16];
h_Prop_Norm = 0.7855*[-3/16, 31/32, 0, -31/32, 3/16];
[Freq_Resp_CentDiff,Freq] = freqz(h_CentDiff,1);
[Freq_Resp_Prop,Freq] = freqz(h_Prop,1);
[Freq_Resp_Prop_Norm,Freq] = freqz(h_Prop_Norm,1);
Mag_CentDiff = abs(Freq_Resp_CentDiff);
Mag_Prop = abs(Freq_Resp_Prop);
Mag_Prop_Norm = abs(Freq_Resp_Prop_Norm);
figure(1), clf
subplot(2,1,1)
plot([0, pi],[0, pi],':k') % Ideal freq mag response
hold on
plot(Freq, Mag_CentDiff,'g', Freq, Mag_Prop,'k')
hold off
axis([0, pi, 0, 3])
ylabel('Gain'), grid on, zoom on
title('CenDiff = green, Proposed = black')
subplot(2,1,2)
hold on
plot(Freq, Mag_CentDiff,'g', Freq, Mag_Prop_Norm,'k')
hold off
axis([0, pi, 0, 3]), xlabel('Freq (Radians/Sample)')
title('CenDiff = green, Proposed-Normalized = black')
Nice article Rick!
I see that Neil also wrote an article summarizing various differentiators and quantifying their noise performance; I was curious if such an article (or perhaps this is in one of your books) exists summarizing the mean error for both magnitude and phase for different discrete time differentiators?
Phase is often overlooked but can be an important consideration; I was particularly curious how a Tustin (Bilinear Transform) mapped differentiator would compare in the pile of options since that would provide an exact phase match over all frequencies (and distorts the amplitude due to the "frequency compression" property of that mapping technique). A Tustin mapped differentiator would be implemented as:
H(s) = s
H(z) = (z-1)/(z+1)
y[n] = x[n] - x[n-1] - y[n-1]
Hi Dan. I just now saw your "Reply" here.
Because the discrete differentiators I've described in my blogs all have linear phase I didn't discuss their phase responses to any meaningful degree.
When I model your above H(z) = (z-1)/(z+1) transfer function it behaves like a resonator rather than a discrete differentiator. I must be missing something here.
Ha! Just finally seeing your reply to my reply (we are going in slow motion). Yes I think I see what you mean. Unless you look at it on a log log scale, the high frequency noise enhancement makes us see a "resonator" (which is that frequency compression with the Bilinear transform bringing what would be occurring at positive infinity to Nyquist - so very bad in terms of high frequency noise enhancement!). Here it is on the log log plot where aside from that nasty amplification at Nyquist, it's a perfect differentiator elsewhere! (Magnitude increasing at rate f with the freq compression I mentioned, (add whatever scale you like), and phase exactly +90 degrees everywhere)
Hay Rick,
I have to disagree with you about scaling. You differentiator FIR coefficients are:
This can be viewed as the cascade of the simplest differentiator having coefs:
1, -1
and a low-pass filter (with a little bump in the frequency response) having coefs:
-3/16, 25/32, 25/32, -3/16
All this is fine and good, but that LPF has a DC gain of 19/16 and it really should have a DC gain of 1.
The reason why is that this differentiator (which I think is really good, BTW, except for the scaling error) can be used with other designs for "estimating" instantaneous frequency. I put "estimate" in quotes because we want our "estimate" to be exact. At least if the frequency of the input is constant and there is no noise, the estimated instantaneous frequency should be exactly correct.
We know that instantaneous frequency is the derivative w.r.t. time of the instantaneous phase. But if your differentiator is used (without fixing the scaling) to perform the derivative of instantaneous phase of a simple sinusoid, your resulting frequency will be scaled up by a factor of 19/16. So I am convinced that the denominators should be 19 or 38. The differentiator should have FIR coefficients of:
-3/19, 31/38, 0, -31/38, 3/19
Please take a look at these two DSP Stack Exchange answers to get the low-down on it:
https://dsp.stackexchange.com/questions/98301/inst...
https://dsp.stackexchange.com/questions/76644/a-si...
I'm also asking a question on the Mathematics Stack Exchange about a related problem regarding this instantaneous frequency estimator:
https://math.stackexchange.com/questions/5100778/e...
but no one has answered it yet.
L8r,
r b-j
I **do** understand that. Also if you were doing this with an integer machine.
I just think that this **"Differentiator Gain"** issue that Qasim also talks about is really important. When a discrete-time differentiator is used in an Instantaneous-Frequency estimator (what we're discussing at the DSP SE), this gain is important. It's not like audio or radio where someone can just turn a gain knob and everything still works. If you don't get this gain right, your estimated instantaneous frequency will be wrong, even with a constant-frequency sinusoid in a noise-free environment.
BTW, I left new comments on the DSP SE answer about instantaneous frequency. I'm starting to get into this conceptually, a little.
Yes that totally makes sense. It might be best to present the result with a gain compensator at the start of it (so the missing gain is very clear, but also the nice power of two ratios persist).
