A Matlab Function for FIR Half-Band Filter Design
Half-band filters have -6 dB frequency of 1/4 the sample rate, and odd symmetry of the frequency response about 1/4 the sample rate. Given the odd-symmetry of the response, the passband and stopband edge frequencies are symmetric with respect to fs/4. This symmetry makes the halfband filter ideal for decimation by 2 or interpolation by 2. And, remarkably, the odd-indexed coefficients of FIR half-band filters are zero, except for the main tap coefficient.
This article is available in PDF format for easy printing.
FIR Half-band filters are not difficult to design. In an earlier post [1], I showed how to design them using the window method. Here, I provide a short Matlab function halfband_synth that uses the Parks-McClellan algorithm (Matlab function firpm [2]) to synthesize half-band filters. Compared to the window method, this method uses fewer taps to achieve a given performance. The function’s code is listed at the end of the article. The function call is as follows:
b= halfband_synth(fpass,fs,ntaps)
where
fpass = desired passband edge frequency, Hz. fpass must be less than fs/4.
fs = sample rate, Hz.
ntaps = desired number of filter taps
ntaps + 1 must be an integer multiple of 4, so ntaps = 7, 11, 15, …
ntaps = 3 is not allowed.(For ntaps = 3, the coefficients are [1 2 1]/4).
b = vector of filter coefficients. Given indexing [b0 b1 b2 …], the odd-indexed coefficients are zero, except for the main tap.
Following are two of examples of half-band filter synthesis using the function.
Example 1.
Let fs = 1 Hz, fpass = 0.15*fs, and ntaps = 11. The following Matlab code computes the half-band coefficients.
fs= 1;
fpass= 0.15*fs;
ntaps = 11;
b= halfband_synth(fpass,fs,ntaps);
The function prints fstop to the workspace:
fstop = 0.3500
and it computes the coefficients:
b= [.0163 0 -.0683 0 .3038 .5 .3038 0 -.0683 0 .0163]
The filter has (ntaps + 3)/2 = 7 non-zero coefficients. The coefficients are plotted in Figure 1 (top). The frequency response can be computed as follows:
[H,f]= freqz(b,1,256,fs);
Hmag = abs(H);
HdB= 20*log10(Hmag);
The magnitude of H is plotted in Figure 1 (bottom), showing the odd symmetry with respect to fs/4. Note |H| = 0.5 at fs/4. The dB-magnitude response is plotted in Figure 2, where we see that the response is equiripple in the stopband (top) and passband (bottom), as expected from the Parks-McClellan algorithm.
Figure 1. Top: 11-tap half-band filter coefficients. Bottom: Magnitude response.
Figure 2. Top: 11-tap half-band filter dB-magnitude response.
Bottom: dB-magnitude response in the passband.
Example 2.
Let fs = 200 Hz, fpass = 40 Hz, and ntaps = 35. The following Matlab code computes the half-band coefficients.
fs = 200;
fpass= 40;
ntaps = 35;
The filter has (ntaps + 3)/2 = 19 non-zero coefficients. The coefficients and magnitude response are plotted in Figure 3. The dB-magnitude response is plotted in Figure 4.
Figure 3. Top: 35-tap half-band filter coefficients. Bottom: Magnitude response.
Figure 4. 35-tap half-band filter dB-magnitude response.
How It Works
The simplest method for designing an equiripple half-band FIR filter would be to compute the stopband edge frequency that is symmetrical about fs/4 with the passband edge frequency, and set a goal function and frequencies as follows, where fpass is passband edge frequency and fs is sample frequency:
fstop = fs/2 - fpass % Hz stopband edge frequency
a= [1 1 0 0]; % amplitude goal function
f= [0 fpass fstop fs/2]/(fs/2); % normalized frequencies
The coefficients would be computed using firpm. The odd-index coefficients from firpm would be close to zero, but not exactly zero. These coefficients would then be set to exactly 0.
Here, we use a more accurate method described by Vaidyanathan and Nguyen [3]. To illustrate the method, we start by considering the half-band filter coefficients from Example 1:
Now define coefficients g:
g = 2*b(1:2:end) (1)
= 2*[.0163 -.0683 .3038 .3038 -.0683 .0163]
The magnitude response |H(f)| of coefficients b is plotted in the top of Figure 5, and the magnitude response |G(f)| of coefficients g is plotted in the bottom. The passband edge of |G| is exactly 2*fpass, where fpass is the passband edge of |H|, and |G| is zero at fs/2. We call g a one-band filter.
Now let’s reverse this process by first synthesizing the one-band filter g and using it to compute the half-band filter coefficients b. The passband edge is 2*fpass and the stopband is just the single frequency fs/2, so we can specify an ideal |G(f)| as follows:
a = [1 1 0 0]; % amplitude goal function
f = [0 2*fpass fs/2 fs/2]/(fs/2); % normalized frequencies
The desired filter b has ntaps = 11, and the length of g is:
gtaps = (ntaps + 1)/2 = 6 (2)
Now g can be synthesized using firpm:
g = firpm(gtaps-1,f,a);
The half-band filter b is realized by inserting zeros between the elements of g/2, which is the inverse of the process shown in Equation 1. Finally, the main tap is set to 0.5. The synthesis process requires only gtaps = (ntaps + 1)/2 coefficients, vs ntaps for the conventional approach. This results in quicker computation and more accurate coefficients.
Figure 5. Top: Magnitude response |H| of coefficients b.
Bottom: Magnitude response |G| of coefficients g.
Matlab Function halfband_synth
The code for the function halfband_synth is listed below. The number of taps is called ntaps. ntaps + 1 must be an integer multiple of 4, so ntaps = 7, 11, 15, … It is possible to design a half-band filter with an even number of taps, but this results in a filter with no zero-valued coefficients. The cases ntaps = 9, 13, 17, …, are not used because the end coefficients are zero. Finally, note that Matlab has a function to design half-band filters in the DSP System Toolbox [4].
Disclaimer: I believe this code to be correct, but it may contain errors. Be sure to verify the coefficients before using them in a design.
% halfband_synth.m 7/2/25 Neil Robertson
% Half-band filter synthesis function using firpm,
% based on Vaidyanathan and Nguyen [3].
% b = halfband_synth(fpass,fs,ntaps)
% fs = sample rate, Hz.
% fpass = passband edge frequency, Hz. fpass < fs/4.
% ntaps = number of taps. ntaps = 7, 11, 15, ...
% b = vector of filter coefficients.
function b = halfband_synth(fpass,fs,ntaps)
if fpass >= fs/4
error('fpass must be less than fs/4')
end
if mod((ntaps+1),4) ~= 0
error('ntaps+1 must be an integer multiple of 4')
end
f = [0 2*fpass fs/2 fs/2]/(fs/2); % frequencies for optimization
gtaps = (ntaps + 1)/2; % one-band filter number of taps
g = firpm(gtaps-1,f,a); % one-band filter coefficients
b = zeros(1,ntaps);
b(1:2:end) = g/2; % half-band coefficients
b(gtaps) = .5; % center tap coefficient
References
1. Robertson, Neil, “Simplest Calculation of Half-band Filter Coefficients”, DSPRelated.com, Nov., 2017,
https://www.dsprelated.com/showarticle/1113.php
2.Matlab website, “firpm”, https://www.mathworks.com/help/signal/ref/firpm.html
3.Vaidyanathan, P. P., and Nguyen, Truong Q., “A ‘Trick’ for the Design of FIR Half-Band Filters”, IEEE Transactions on Circuits and Systems, VOL CAS-34, No. 3, March 1987. https://authors.library.caltech.edu/records/czbzh-df707
4.Matlab website, “FIR Halfband Filter Design”,https://www.mathworks.com/help/dsp/ug/fir-halfband-filter-design.html
Neil Robertson, July 2025
You might also like
- Comments
Hi Neil,
Thanks for the article.
According to your function, Fpass must be less than halfband (Fs/4).
This leads to the question on the term "halfband".
I though it is always halfband but if less then what are the criteria for such filter:
1) is it the design of alternating zeros or equiripple between passband and stop band or both.
2) zeros are useful but is equiripple useful or just secondary byproduct of design.
Kaz
Hi Kaz,
The design criterion in the frequency domain is that |H| = 0.5 at f = fs/4 and odd-symmetry about fs/4 with respect to amplitude of 0.5.
This then results in every other tap being zero (except main tap). There is no requirement for equiripple behavior. For example, you can achieve a half-band filter using the window method, as shown in reference 1.
regards,
Neil
Thanks Neil, that definition covers better.
But raises another question: Why cut off short of Fs/4 as it puts more strain on filtering?
Kaz
Kaz,
I'm not sure I understand your question. For a given passband ripple, lower fpass requires fewer taps. Example 1 in the article had fpass = 0.15*fs, and had 11 taps. Example 2 had fpass = 40/200 *fs = 0.2*fs, and had 35 taps. (Not apples to apples, since Example 2 had lower ripple and better stopband attenuation, but you get the idea).
Of course, for the non-symmetric case of a given fstop/fpass ratio, lower fpass requires more taps. But this is not the case we are dealing with here.
-- Neil
Hello,
The half-band filter has symmetry about Fs/4 and can be low-pass or high pass depending on whether the center tap is added or subtracted. The area around Fs/4 is in the middle of the transition band. In fact the closer the pass band cut off is to DC the *fewer* taps are required because the transition band is wider.
The main application is for decimation or interpolation usually by a factor of 2.
For more on the topic fred harris book on multirate DSP is fantastic.
Cheers,
Mark Napier
Hi Mark,
There is an error in Harris's Matlab code for half-band design in section 8.4.1 of his book: the last line should be:
h3(11) = 0.5;
The design "trick" used by Harris is described in reference 3.
-- Neil
When you need quantization on few bits :
% Nine Digital Filters for Decimation and interpolation
% DAVID J. GOODMAN, MEMBER, IEEE, AND MICHAEL J. CAREY
% IEEE TRANS. ASSP-29, NO. 2, APRIL 1977
b1=1/2 * [1 1 1];
b2=1/2 * [1 2 1];
b3=1/16 * [-1 0 9 16 9 0 -1];
b4=1/64 * [-3 0 19 32 19 0 -3];
b5=1/512 * [3 0 -25 0 150 256 150 0 -25 0 3];
b6=1/692 * [9 0 -44 0 208 346 208 0 -44 0 9];
b7=1/1024 * [7 0 -53 0 302 512 302 0 -53 0 7];
b8=1/1610 * [-6 0 33 0 -116 0 490 802 490 0 -116 0 33 0 -6];
b9=1/16384 * [18 0 -116 0 429 0 -1277 0 5042 8192 5042 0 -1277 0 429 0 -116 0 18];
Thanks. That's an "oldie but goodie" paper.
Indeed, too old. I wonder if [1 1 1] is really a filter
