Least-squares magic bullets? The Moore-Penrose Pseudoinverse
Hello,
the topic of this brief article is a tool that can be applied to a variety of problems: The Moore-Penrose Pseudoinverse.
While maybe not exactly a magic bullet, it gives us least-squares optimal solutions, and that is under many circumstances the best we can reasonably expect.
I'll demonstrate its use on a short example. More details can be found for example on Wikipedia, or the Matlab documentation for pinv.
The complete Matlab example is here (the link opens a new window).
The purpose of this blog entry is to provide additional information to the example program.
Problem
This picture may look more familar to electronics engineers than we'd like: The blue trace could be a measured signal that has picked up power line hum.
The corresponding variable in the Matlab example is measuredSignal, a column vector with one entry per measured sample.
We'd like to reconstruct the hum signal from the measured signal (red trace), based on the knowledge of possible hum waveforms.
Setting up the equation system
I do know the exact frequency of the power line hum and its harmonics, but I do not know amplitude and phase of each term.
First, I set up a matrix with my "basis" waveforms: index=[1:m]' is a column vector with the sample numbers. The resulting basis matrix has one row per sample, and one column for each of the six candidate waveforms.
Next, I calculate the Moore-Penrose Pseudoinverse using pinv(basis), and take a matrix-vector product with the measured signal.
As a result I get a column vector with one coefficient per basis waveform. These coefficients are my least-squares solution, fitting the known waveforms to the original signal:
Next, I reconstruct the hum signal by weighting each basis waveform with its least-squares coefficient and adding the weighted waveforms:
What remains is to subtract the reconstructed hum signal from the measured data.
Voilà, here is the corrected signal:
The picture shows:
- The ideal, undisturbed signal
- The remainder, after subtracting reconstructedHum from measuredSignal
- The difference with regard to the ideal signal (error)
Even though the signal was completely overwhelmed by power line hum in the first picture, we were able to remove the hum almost completely. Not too bad...
For interpretation: The processing has removed as much as possible of the signal energy (sum of squares) by scaling the known waveforms. Or in other words: The remaining signal is the component of the input signal that cannot be "explained" by the basis waveforms.
Of course, if the ideal signal has components that look like power line hum ("can be explained by the basis waveforms"), those will also be removed.
The accuracy increases with the square root of the number of independent samples m. For example, to reduce the error by 3 (10) dB, it takes 4 (100) times more samples.
On a modern PC, surprisingly large problems can be handled.
A Moore-Penrose Pseudoinverse is a computationally expensive operation. But note that it is applied to the basis waveforms, not the signal. In order to process many signals of the same (or shorter) length, it needs to be computed only once.
Applying it to the measured signal involves only one "dot" (scalar) product between two vectors per coefficient.
Thanks for reading! I hope the example will be useful.
Link
Complete Matlab example, ready to run: here.
You might also like
- Comments
But we have to use pseudoinverse, if we add columns into matrix, which are linear combinations of original columns. In this case, matrix rank will stay 6, while number of columns will be bigger. For such matrix there is no way to use typical way and pseudoinverse is required.
thank you for the comment.
When you write
>> "The usual way: inv(basis' * basis) * basis' * measuredData "
this already puts it out of reach of most "practical" engineers, who aren't DSP-specialized, and/or have left their "math IV" exam behind a long time ago.
No, my intention with this article - which isn't paying any attention at all to linear algebra - is to advertise the method as a general problem solving tool. It is particularly attractive because a large class of problems can be solved with a common pattern. It may be inefficient, but I wouldn't see this as a problem in offline calculations. Instead, "one size fits all" is the main selling point. Also, the pinv-equation or the similar "magic backslash operator" in Matlab are easy to remember.
Someone implementing the same on limited resources would need to spend more time with the calculation, decide what is really necessary and how can it be done efficiently. But that is clearly not the target audience here.
Practically, I can't remember any DSP-model, where columns might be linearly dependent and pseudoinverse is needed. Do you know any examples?
>> I agree, backslash is enough and we don't even need to mention pseudoinverse.
Coming soon: The sequel, titled "LS Episode II: The Backslash".
I bet it will attract readers out of sheer curiosity :)
